Component: MIAC GSM (MIAC: Addon Modules)
Author
Category MIAC: Addon Modules
MIAC GSM component
GSM Addon for MIAC System.
FREE
Fc9-comp-macro.png GSM_SetStart
Sets the state of the GSM module Start pin. (Low level GSM interface)
Fc9-u8-icon.png - BYTE State
Fc9-comp-macro.png GSM_CheckNetworkStatus
Returns the state of the GSM network. 0 = Not connected, 1 = connected, 255 = no reply from GSM.
Fc9-comp-macro.png GSM_SendScript
Send an AT command script. Returns 0 for fail, 1 for success and 255 for unrecognised script idx.
Fc9-u8-icon.png - BYTE idx
Fc9-comp-macro.png GSM_SendTextMessage
Sends the text message data specified to the number specified using the SMS protocol. Returns 0 for success and 255 for failure.
Fc9-string-icon.png - STRING Number
Fc9-string-icon.png - STRING Message
Fc9-comp-macro.png GSM_SendCommand
Sends a command string to the GSM module. 0 = Command sent ok, 255 = No Reply
Fc9-string-icon.png - STRING Command
Fc9-u8-icon.png - BYTE SendCR
Fc9-comp-macro.png GSM_GetCharCount
Returns the number of characters waiting to be read from the receive buffer. (Low level GSM interface)
Fc9-comp-macro.png GSM_CheckForIncoming
Checks to see if any incoming phone call or SMS message. 0 = Nothing, 1 = Text Received, 2 = Phone Ringing
Fc9-comp-macro.png MIAC_Module_SetData
Fc9-u8-icon.png - BYTE Count
Fc9-u8-icon.png - BYTE D0
Fc9-u8-icon.png - BYTE D1
Fc9-u8-icon.png - BYTE D2
Fc9-u8-icon.png - BYTE D3
Fc9-u8-icon.png - BYTE D4
Fc9-u8-icon.png - BYTE D5
Fc9-comp-macro.png MIAC_Module_Init
Fc9-u16-icon.png - UINT CAN_ID
Fc9-comp-macro.png GSM_HangUpCall
Ends a voice based call. Returns 0 for success and 255 for failure.
Fc9-comp-macro.png MIAC_Module_GetData
Fc9-u8-icon.png - BYTE Index
Fc9-comp-macro.png GSM_SetReset
Sets the state of the GSM module Reset pin. State = 0 will hold the module in the reset state (Low level GSM interface)
Fc9-comp-macro.png GSM_DialNumber
Performs a standard voice call by dialling the number specified. Returns 0 for call in progress and 255 for no response.
Fc9-comp-macro.png GSM_StringReceive
Attempts to receive a string from the GSM modem. Returns 1 if successful, 0 on timeout
Fc9-comp-macro.png MIAC_Module_Message
Fc9-u16-icon.png - UINT CMD_ID
Fc9-comp-macro.png MIAC_Module_WR
[[File:]] - Count
[[File:]] - Start
[[File:]] - More
Fc9-comp-macro.png LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
Fc9-comp-macro.png GSM_AnswerIncomingCall
Answers the phone for an incoming type call. Returns 0 for success and 255 for failure.
Fc9-comp-macro.png GSM_SetRTS
Sets the state of the GSM module RTS pin. (Low level GSM interface)
Fc9-comp-macro.png MIAC_Module_PushData
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png GSM_Initialize
Resets and restarts the GSM module Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail.
Fc9-comp-macro.png GSM_SendCharacter
Sends the byte character to the GSM module. (Low level GSM interface)
Fc9-u8-icon.png - BYTE Byte
Fc9-comp-macro.png GSM_ReadString
Copies the data from the data string array to a local string variable
Fc9-u8-icon.png - BYTE NumBytes
Fc9-comp-macro.png DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
Fc9-u8-icon.png - BYTE Terminal
Fc9-u8-icon.png - BYTE Value
Fc9-comp-macro.png GSM_GetTextString
Collects the text message data from an incoming text message.
Fc9-comp-macro.png MIAC_Module_GetAck
Fc9-u16-icon.png - UINT TimeOut
Fc9-comp-macro.png GSM_GetStatus
Returns status bits from the GSM module. Bit 6 = CTS, Bit 12 = STATUS (LED), Bit 13 = RING (Low level GSM interface)
Fc9-comp-macro.png AnalogInput
Read the ADC value of a Terminal Returns 12 bit ADC reading
Terminal number to be read
Fc9-comp-macro.png GSM_GetTextNumber
Collects the sender's phone number from an incoming text message.
Fc9-comp-macro.png DigitalInput
Read the value of a terminal
Fc9-comp-macro.png GSM_GetCharacter
Returns the next character waiting to be read from the receive buffer. (Low level GSM interface)
Fc9-type-16-icon.png Module Type
Fc9-type-16-icon.png Module Address
Fc9-type-16-icon.png Script Count
Maximum number of scripts to store in the device's ROM
Fc9-type-11-icon.png Script1
ASCII based AT command data stored in ROM and used when sending script 1
Fc9-type-16-icon.png Expect Echo
