Component: LED Template (Outputs: LEDs)
Version 1.3 (Development)
Category Outputs: LEDs
Image LED Template component
Base for creating LEDs and other on/off visual indicators. Choose a 'Target Object' that will change colour when the pin changes; if multiple objects must change color, group them, and target the group. When 'Auto off color" is selected, changing the 'on color' will automatically choose an off color by reducing the on-color intensity.
This component can be used as a base to create child components
The following components all inherit the traits of LED Template:
Image Dashboard lamp Indicator with bezel and label, particularly suitable for viewing on the dashboard.
Indicator on/off colors, bezel color and label all editable via properties.
Image LED (LES, Panel) Panel lamp for a LES bulb.
Colour can be changed in component properties.
Image LED (5mm, PCB) An industry standard 5mm diameter LED.
Any color may be chosen, and the leads trimmed to length.
Image LED (5mm, Panel) Standard 5mm LED mounted in a panel clip. Colour can be changed in component properties.
Image LED (SMD, PCB) Surface mount LED in standard PLCC2 package.
Colour can be set friom component properties.
Image LED (Generic) Basic LED component using simple geometric shapes.
LED Resistor Calculator Tool
TurnOn
Turn the LED off.
This macro has no parameters
TurnOff
Turn the LED on.
Simulation macro reference
Pin
This property is of type Single digital pin and can be referenced with the variable name pin.
Chip pin to connect the LED to.
Polarity
This property is of type Fixed list of ints and can be referenced with the variable name polarity.
Active High: Pin true -> On color, Pin false -> Off color
Active Low: Pin true -> Off color, Pin false -> On color
Target Object
This property is of type Panel object and can be referenced with the variable name target_object.
Set a target object to be the illuminating part of the LED.
To change the colour of multiple objects, group them first, then target the group.
On Color
This property is of type Color picker and can be referenced with the variable name on_color.
The color of the LED when it is turned on.
Off Color
This property is of type Color picker and can be referenced with the variable name off_color.
The color of the LED when it is turned off.
Auto Off Color
This property is of type True or false and can be referenced with the variable name auto_off.
When this is selected, the off color is automatically set to a darker version of the on color.
