Component: MIAC Serial (MIAC: Addon Modules)
(Redirected from Component: ID 126523d0 e391 4ccb 86c0 0e9d1b33d5f0)
Jump to navigationJump to searchAuthor | |
Version | 1.0 |
Category | MIAC: Addon Modules |
MIAC Serial component
Serial Addon expansion module for MIAC System
FREE
UART_ReceiveChar |
Timeout |
Return |
FAT_OpenFile |
Filename |
Return |
PWM_Enable |
Enable the PWM on Channel 1 or 2 | |
Channel |
PWM Channel 1 or 2 | |
Return |
MI2C_Send_Byte_Transaction |
[[File:]] - | Device_ID |
[[File:]] - | AddrH |
[[File:]] - | AddrL |
[[File:]] - | Data |
Return |
SERIAL_ReceiveChar |
Timeout |
Return |
FAT_Init |
Return |
SERIAL_SendChar |
Character |
Return |
SPI_Uninit |
Return |
MI2C_Stop |
Return |
UART_SendString |
Text |
Return |
MIAC_Module_SetData |
Count |
D0 |
D1 |
D2 |
D3 |
D4 |
D5 |
Return |
FAT_ScanCurrentFolder |
idx |
type |
Scan type | |
Return |
MIAC_Module_Init |
CAN_ID |
Return |
MIAC_Module_GetData |
Index |
Return |
SPI_Init |
Return |
FAT_AppendStringToFile |
Text |
Return |
MIAC_Module_Message |
CAN_ID |
CMD_ID |
Return |
MIAC_Module_WR |
CAN_ID |
CMD_ID |
[[File:]] - | Count |
[[File:]] - | Start |
[[File:]] - | More |
Return |
MI2C_Restart |
Return |
FAT_OpenFolder |
Folder |
Return |
LED_Control |
Sets the indicator LED On (State=1) or Off (State=0) | |
State |
Return |
SPI_Get_Char |
[[File:]] - | Return |
UART_Initialize |
Return |
FAT_MoveToNextFileSector |
force |
force next sector | |
Return |
FAT_ReadByteFromScan |
idx |
Return |
SPI_Send_Char |
[[File:]] - | Char |
Return |
FAT_ReadFileLength |
Return |
MI2C_Transmit_Byte |
FAT_CreateFile |
Filename |
Return |
MIAC_Module_PushData |
Data |
Return |
MI2C_Receive_Byte |
[[File:]] - | Last |
Return |
MI2C_Init |
Return |
PWM_Disable |
Disable the PWM on Channel 1 or 2 | |
Channel |
Return |
SERIAL_ReceiveString |
Timeout |
NumBytes |
Return |
FAT_WriteFileSector |
Return |
SERIAL_SendString |
Text |
Return |
MI2C_Receive_Byte_Transaction |
DigitalOutput |
Set a Terminal Output to High (Value=1) or Low (Value=0) | |
Terminal |
Value |
Return |
FAT_ReadByteFromBuffer |
address |
Return |
MIAC_Module_GetAck |
CAN_ID |
CMD_ID |
TimeOut |
Return |
FAT_ReadFileSector |
Return |
FAT_WriteByteToBuffer |
address |
data |
Return |
SERIAL_Initialize |
Return |
FAT_DeleteFile |
Filename |
Return |
AnalogInput |
Read the ADC value of a Terminal Returns 12 bit ADC reading | |
Terminal |
Terminal number to be read | |
Return |
Initialize |
Forces a software reset on the module | |
Return |
UART_ReceiveString |
Timeout |
NumBytes |
Return |
PWM_SetDuty |
Sets the PWM Duty cycle on Channel 1 or 2 | |
Channel |
Duty |
Duty cycle (8 bit value) | |
Return |
MI2C_Start |
Return |
DigitalInput |
Read the value of a terminal | |
Terminal |
Return |
UART_SendChar |
Character |
Return |
