Component: RGB Xmas Tree (Misc Circuit)
(Redirected from Component: ID 144a220f 7bc3 4b73 bc56 f9c7203bf204)
Jump to navigationJump to searchAuthor | MatrixTSL |
Version | 1.0 |
Category | Misc Circuit |
RGB Xmas Tree component
Component complete with macros and simultion to drive the MatrixTSL RGB Xmas Tree decoration.
FREE
For more information please refer to the Xmas Tree blog post.
PlayNote |
Plays a specific note for the length of time specified. | |
Note |
0-59 - 0=C, 1=C#, 2=D, 3=Eb, 4=E, 5=F, 6=F#, 7=G, 8=G#, 9=A, 10=Bb, 11=B, 12=C... | |
Length |
Return |
RandomLED |
Randomises the colour to a specific LED | |
LED |
LED 0 to NumLEDs - 1 | |
Return |
SetLED |
Directly sets the colour of a single LED. Red = 3-bit, Green = 3-bit, Blue = 2-bit 0bBBGGGRRR | |
LED |
Colour |
Return |
JingleBells |
Plays the Jingle Bells tune using the audio driver. | |
Return |
SetLEDs |
Sets the colour of all the LEDs. Red = 3-bit, Green = 3-bit, Blue = 2-bit 0bBBGGGRRR | |
Colour |
Return |
CheckSwitch |
Checks to see if the switch is pressed. Returns 1 to indicate a press and 0 to indicate not pressed. | |
Return |
CheckAudio |
Checks to see if the audio circuit is current outputting a tone. Returns 1 to indicate audio active and 0 to indicate not active. | |
Return |
RandomLEDs |
Randomises the colour of all the LEDs | |
Return |
GetLED |
Directly read the colour of a single LED. Red = 3-bit, Green = 3-bit, Blue = 2-bit 0bBBGGGRRR | |
LED |
Return |
Initialise |
Starts up the LED PWM and Audio software driver. | |
Return |
Properties |
Pin Connections |
File:Fc9-type-19-icon.png | LED Data Port |
LED Clock Pin |
LED Enable Pin |
Audio Output Pin |
Switch Input Pin |
LED Properties |
Number Buffers |
Number of octal buffer IC's you will require to drive the LEDs. Note that the microcontroller data port provides the first buffer so the numbr of ICs is actually one less than the value shown. | |
Number LEDs |
Test On Startup |
Performs a simple LED test routine on start up. LEDs should all light up white, red, green and blue in second intervals. |
