Component: MIAC (PIC) CAN Slave (MIAC: Addon Modules)
Version 1.4
Category MIAC: Addon Modules
MIAC (PIC) CAN Slave component
MIAC Slave for MIAC System. Requires Slave firmware program downloaded to a MIAC (PIC) to act as a CAN connected Slave device.
FREE
Fc9-comp-macro.png InputANALOG_10Bit
Returns the 10 bit value for the analogue input requested by parameter InputID (Inputs 1 to 8)
Fc9-u8-icon.png - BYTE InputID
The input to read from 1 to 8.
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png RelayOFF
Turns off the requested relay given by parameter RelayID, values 1 to 4
Fc9-u8-icon.png - BYTE RelayID
The relay to turn off. From 1 to 4.
Fc9-comp-macro.png PrintString
Prints the given character string to the display at the current cursor position and moves the cursor position.
The string to send to the display.
Fc9-comp-macro.png GetKeypad
Returns the key code of the key that is pressed, otherwise if nothing is pressed then returns 255
Fc9-comp-macro.png DisplayStart
Initialise the display ready for use
Fc9-comp-macro.png DisplayCommand
Sends the given command to the display
Fc9-u8-icon.png - BYTE Cmd
Fc9-comp-macro.png PrintASCII
Prints the given character to the display at the current cursor position and increments the cursor position.
Fc9-u8-icon.png - BYTE Char
ASCII code of the character to print.
Prints the given number to the display starting at the current cursor position and moves the cursor position.
Fc9-s16-icon.png - INT n
Fc9-comp-macro.png MIAC_Module_SetData
Fc9-u8-icon.png - BYTE Count
Fc9-u8-icon.png - BYTE D0
Fc9-u8-icon.png - BYTE D1
Fc9-u8-icon.png - BYTE D2
Fc9-u8-icon.png - BYTE D3
Fc9-u8-icon.png - BYTE D4
Fc9-u8-icon.png - BYTE D5
Fc9-comp-macro.png PrintFormattedNumber
Fc9-u32-icon.png - ULONG Number
Fc9-bool-icon.png - BOOL Format
0=Signed, 1=Unsigned
Fc9-comp-macro.png MIAC_Module_Init
Fc9-u16-icon.png - UINT CAN_ID
Fc9-comp-macro.png MIAC_Module_GetData
Fc9-u8-icon.png - BYTE Index
Fc9-comp-macro.png MIAC_Module_Message
Fc9-u16-icon.png - UINT CMD_ID
Fc9-comp-macro.png DisplayClear
Clears the display to white space
Fc9-comp-macro.png MIAC_Module_WR
[[File:]] - Count
[[File:]] - Start
[[File:]] - More
Fc9-comp-macro.png MIAC_Module_PushData
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png OutputOFF
Outputs a digital low state on the output requested by parameter TransID (Outputs 1 to 4)
Fc9-u8-icon.png - BYTE TransID
1 to 4 (Outputs A to D)
Fc9-comp-macro.png RelayON
Turns on the requested relay given by parameter RelayID, values 1 to 4
The relay to turn on from 1 to 4.
Fc9-comp-macro.png DisplayCursor
Moves the display cursor to the given position. If the cursor is set to the origin at x=0, y=0, then the next character sent to the display will appear in the top left corner.
Fc9-u8-icon.png - BYTE x
Position of the cursor in characters from left to right.
Fc9-u8-icon.png - BYTE y
The line to move the cursor to.
Fc9-comp-macro.png OutputON
Outputs a digital high state on the output requested by parameter TransID (Outputs 1 to 4)
Fc9-comp-macro.png InputDIGITAL
Returns the digital state of the input requested by parameter InputID (Inputs 1 to 8)
The input number from 1 to 8.
Fc9-comp-macro.png MIAC_Module_GetAck
Fc9-u16-icon.png - UINT TimeOut
Returns the 8 bit value for the analogue input requested by parameter InputID (Inputs 1 to 8)
Fc9-type-16-icon.png Module Type
Fc9-type-16-icon.png Module Address
