Component: GLCD (ST7565R) SPI (Graphical Monochrome)
Version 1.5
Category Graphical Monochrome
GLCD (ST7565R) SPI component
Graphical display component designed to work with the ST7565 type monochrome displays. Transfers data using a 4-wire SPI interface, cannot read back so pixel based routines won't work.
DISPLAYS
Fc9-u8-icon.png - BYTE Font
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png BPlot
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
Fc9-comp-macro.png DrawCircle
Fc9-comp-macro.png Write_Command
Fc9-u8-icon.png - BYTE Command
0=White, 1=Black
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png Dimensions
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-16-icon.png MOSI Remap Pin
Fc9-type-5-icon.png MISO
Fc9-type-16-icon.png MISO Remap Pin
Fc9-type-5-icon.png CLK
Fc9-type-16-icon.png CLK Remap Pin
Fc9-type-5-icon.png CS
Chip select pin
Fc9-type-5-icon.png A0
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Display Method
Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
