Component: IoT Made Easy (Comms: IoT/Cloud)
(Redirected from Component: ID 2740a93b 32a9 48d1 8fc3 089d13b50bb5)
Version | 1.0 |
Category | Comms: IoT/Cloud |
IoT Made Easy component
A component designed to simplify MQTT comms allowing for multiple data streams to be dealt with in a simple manner. Deals with translating values to and from the broker from topic strings into message IDs and numeric values. Works with lots of different MQTT brokers.
FREE
ErrorAsString |
Error |
Return |
GetTopicID |
Compares the topic ID of the last received message with enabled IDs. Returns the topic ID received. | |
Return |
Connect |
Connect to the MQTT Server. Returns the connected state. 0 if not connected, 1 if successful connection, or already connected. | |
Return |
GetPayloadInteger |
Get the Payload of the last received (Read) packet as a signed long value | |
Return |
LastError |
Returns the last error | |
Return |
Read |
Read incoming data. Returns non-zero if packet received. Use GetTopicID and GetPayloadXXX to read the contents. | |
Return |
Disconnect |
Disconnects from the MQTT server and the network | |
Return |
GetPayloadFloat |
Get the Payload of the last received (Read) packet as a floating point value | |
Return |
GetPayloadString |
Get the Payload of the last received (Read) packet as a string value | |
Payload |
Size |
Return |
Initialise |
Starts up the MQTT component - call this after initialising the NetworkComms component. | |
Return |
