Component: Button helper (Helpers)
Version 1.1
Category Helpers
Button helper component
A button overlay that allows any object to behave like a button
FREE
Fc9-comp-macro.png GetStateFor
Returns true if the button is depressed, else false
Fc9-h32-icon.png - HANDLE Target
Fc9-comp-macro.png Clear
Clears all objects from the lists This leaves no links for the button helper
Fc9-comp-macro.png SetDisabledPos
Sets the position of the released button
Fc9-h32-icon.png - HANDLE PositionHandle
A handle to the position of the depressed location
Fc9-comp-macro.png SetEnabledPos
Sets the position of the depressed button
Fc9-comp-macro.png SetAxis
Sets the movement axis as an Axis_... constant
Fc9-u8-icon.png - BYTE Axis
Movement axis to set to, default 4
Fc9-comp-macro.png SetDisabledPosFor
Sets the disabled position for an object
Fc9-comp-macro.png GetTarget
Gets the target handle the property links to
Fc9-comp-macro.png Register
Adds the object to the list if not already there
Fc9-comp-macro.png SetNotify
Sets the object to notify when the button is pressed or released
Fc9-h32-icon.png - HANDLE Handle
The handle of the object - 0 to use the caller object
Fc9-u32-icon.png - ULONG Ident
The identifier to send in the System.Notify message
Fc9-comp-macro.png SetLatchingFor
Sets whether the button is depressed when the mouse is released
Fc9-bool-icon.png - BOOL Enabled
Fc9-comp-macro.png SetMode
Sets the animation mode for the button
Fc9-u8-icon.png - BYTE Mode
0=User, 1=Up/Down, 2 = Lever
Fc9-comp-macro.png SetEnabledPosFor
Sets the enabled position for an object
Fc9-comp-macro.png SetPivotPosFor
Sets the position the lever rotates around for an object
Fc9-comp-macro.png SetModeFor
The target object, 0 for 'set default'
Fc9-comp-macro.png SetMovement
Sets the movement in units or PI/16 steps for the button
Fc9-f32-icon.png - FLOAT Move
Movement to set to - default is 4
Fc9-comp-macro.png SetAxisFor
Sets the position of the object the lever rotates around
Fc9-comp-macro.png SetAutoReset
Sets the state of the auto-reset flag If the flag is true (it is by default) then Button Helper will reset the state of each button on stop
Fc9-bool-icon.png - BOOL State
Set true to reset to off on sim stop, else false to retain state
Fc9-comp-macro.png Unregister
Removes the object to the list if present
Fc9-comp-macro.png SetMovementFor
Movement to set to, default 4
Fc9-type-17-icon.png Host component
Fc9-type-17-icon.png Lever pivot
