Component: Simulation Switch Template (Controls)
Version 1.3
Category Controls
Simulation Switch Template component
A base for building switches that do not download to chip. Mouse interaction can send 'System.User' events with the following data... ID = The handle of the switch component sending the message Message = 1 (on) or 0 (off) Current state can also be read via simulation macros.
FREE
Fc9-comp-macro.png GetState
Read the current state of the switch. Returns BOOL true when the switch is on, or BOOL false when off.
Fc9-comp-macro.png SetState
Sets the current state of the switch. BOOL true when the switch is on, or BOOL false when off.
Fc9-bool-icon.png - BOOL SwitchState
Sets the state of the switch
Fc9-type-16-icon.png Operation
Latching = Mouse click to turn on, click again to turn off. Momentary = Mouse click to turn on, release to turn off.
Fc9-type-16-icon.png Send Event
Determine when the component will send a User event to its parent. On Change - Whenever the switch state changes. On Click - Only when the mouse clicks the object. On Release - Only when the mouse is released over the object. Never - No events.
Fc9-type-17-icon.png Moving part
Handle of a panel object that will be the moving part of the switch.
Fc9-type-17-icon.png Pivot object
Object around which the moving part will rotate when rotation is selected as the movement tyoe.
Fc9-type-16-icon.png Type
Set whether the moving part will move linearly or by rotation.
Fc9-type-16-icon.png Axis
Axis along which the moving part will move (for push/slide) or around which it will rotate (rotary).
Fc9-type-15-icon.png Movement
Distance or angle by which the mioving part will move.
Fc9-type-16-icon.png Show
Decide what label to show... None - no labels are displayed Name - shows the component's name Property - shows a property value of the component (a field for the property name will appear below)
Fc9-type-16-icon.png Startup State
Default state of the indicator when loading the project or starting the simulation runtime.
