Component: MULTIUART (SPI2UART) (Comms: System)
Version 2.0
Category Comms: System
MULTIUART component
Uses a high speed SPI connection to enable up to four buffered external UARTs via the MULTIUART modules.
FREE
FC6 Icon.png Simple test program
Fc9-comp-macro.png ReceiveByte
Returns the first received byte held in queue for the selected channel. Recommended to use the CheckRx macro first to collect number of bytes.
Fc9-u8-icon.png - BYTE UART
UART Index Range: 0-3
Fc9-comp-macro.png TransmitString
Adds a byte to the transmit queue for the selected channel.
Fc9-comp-macro.png SetBaud
Fc9-u8-icon.png - BYTE Baud
Fc9-comp-macro.png TransmitByte
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png CheckRx
Returns the number of received bytes held in queue for the selected channel.
Fc9-comp-macro.png CheckTx
Returns the number of bytes held in the transmit queue for the selected channel.
Fc9-comp-macro.png ReceiveString
Returns a string of received bytes held in queue for the selected channel. Recommended to use the CheckRx macro first to collect number of bytes.
Fc9-u8-icon.png - BYTE NumBytes
Fc9-comp-macro.png Initialise
Activates the SPI peripheral and claims control over the I/O pins.
Fc9-conn-icon.png Bus Settings
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-16-icon.png MOSI Remap Pin
Fc9-type-5-icon.png MISO
Fc9-type-16-icon.png MISO Remap Pin
Fc9-type-5-icon.png CLK
Fc9-type-16-icon.png CLK Remap Pin
Fc9-type-5-icon.png CS / SS
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Label used to identify the component on the panel.
Fc9-type-16-icon.png API
