Component: Switch Array (Slide) (Switches)
Author | Matrix Ltd. |
Version | 2.0 |
Category | Switches |
Switch Array (Slide) component
An array of up to eight slide switches, each connected to a single pin of the specified port.
BASICIO
Here is an example Flowcode program to read the values of a switch array.
Switch Array
(5V / 11K) * 10K = 4.54545V
ReadState |
Read the state of the switch at the given index. | |
Index |
The switch to read the status of. | |
Return |
WaitUntilHigh |
Pause the program until the switch at the given index is turned on. | |
Index |
Index of the switch to wait for. | |
Return |
ReadAll |
Reads all of the switches at once, returning a byte containing one bit per switch. | |
Return |
GetHandle |
Retrieves the object handle of the switch component at the given index. | |
Index |
Return |
WaitUntilLow |
Index |
Return |
Properties |
Count |
The number of LEDs in the array from 1 to 8. | |
Connections |
Input Mode |
Choose a single port for all LEDs - pins are allocated in sequence from pin 0 - 7 ...or choose 'Custom pins' to assign each switch individually. | |
File:Fc9-type-19-icon.png | Port |
Polarity |
Active High = LEDs light when the chosen chip pin is ON Active Low = LEDs light when the chosen chip pin is OFF | |
Debounce |
Time in milliseconds allowed for the pin to settle following a change of state. | |
Operation |
Sets whether switches toggle or are press/release. NB) This option can only be set when the original target includes this option. | |
Simulation |
Alignment |
Which 3D axis to align the copies along. | |
Spacing |
The distance between LEDs in the array. LEDs will be spaced symmetrically around the component centre. Use a negative value to reverse the order of the LEDs. | |
Reverse |
Whether to reverse the order of the switches. | |
Show Labels |
Whether to show labels giving each switch's pin connection. | |
Label color |
Color of the port and pin labels |
