Component: GLCD (ST7789V) (Graphical Color)
Version 1.6
Category Graphical Color
GLCD (ST7789V) component
Graphical display component designed to work with the ST7789V 16-bit colour graphical controller IC.
DISPLAYS
Fc9-u8-icon.png - BYTE Font
Fc9-comp-macro.png BacklightOn
Switches on the backlight
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-comp-macro.png Plot
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png FastPlot
Fc9-comp-macro.png BacklightOff
Switches off the backlight
Fc9-comp-macro.png BPlot
Fc9-comp-macro.png Window
Specifies a full screen or sub window of pixels to draw. Useful when used with the FastPlot function to draw bitmaps at high speed.
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
Fc9-comp-macro.png DrawCircle
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png Dimensions
Fc9-type-21-icon.png X Offset
Horizontal offset before the active display pixels.
Fc9-type-21-icon.png Y Offset
Vertical offset before the active display pixels.
Fc9-conn-icon.png Colour
Fc9-type-7-icon.png Invert Colours
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-5-icon.png Data
Data pin connection
Fc9-type-5-icon.png Clock
Clock pin connection
Fc9-type-7-icon.png Use CS
Fc9-type-7-icon.png Toggle CS
Selects if the chip select pin is automatically toggled or left selected. Yes - Slightly slower but allows pins to be multiplexed with other devices. No - Slightly faster.
Fc9-type-5-icon.png Chip Select
Chip select pin connection
Fc9-type-7-icon.png Use Reset
Fc9-type-5-icon.png Reset
Reset Pin
Fc9-type-7-icon.png Use Backlight
Fc9-type-5-icon.png Backlight
Backlight Pin
Fc9-type-7-icon.png Use DC Pin
Selects if the DC pins is available, Yes we use the DC pin to control if a data or commnd is being sent. No we add an extra bit to the data to do the job of the DC pin.
Fc9-type-5-icon.png DC
Data/Command Pin
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Display Method
