Component: Injector (File) (Test Injectors)
(Redirected from Component: ID 50738af3 82a5 4074 a9b8 9f8f80be2b87)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.0 |
Category | Test Injectors |
Injector (File) component
Comms data injector to allow data to be streamed to and from a file during simulation. The component will read data from the incoming file and write data to the outgoing file.
FREE
Example to log the bytes sent via the UART RS232 component to a file as comma separated decimal numbers.
LogToFile
Contents of the file in the Flowcode project directory after running the simulation.
UARTBaud |
Channel |
Rate |
Return |
UARTCheckRX |
Channel |
Return |
UARTInitialise |
Channel |
Return |
SPITransfer |
Transfer a byte using the SPI bus | |
Channel |
Channel Index: Range 0 - SPI Bus Count - 1 | |
DataOut |
Return |
GetConsoleHandle |
Gets the handle to the console allowing data displaying on the panel etc. | |
Return |
SPIPrescaler |
Modify the speed of the SPI bus | |
Channel |
Prescaler |
Range: 0-2 | |
Return |
UARTReceive |
Channel |
Return |
SPIInitialise |
Initialsie the SPI module ready for communications | |
Channel |
Return |
UARTSend |
Channel |
Data |
Return |
