Component: MIAC (dsPIC) (MIAC (dsPIC)) (MIAC Module)
(Redirected from Component: ID 596e6f4d d87a 4e8b b108 c0501127c382)
Version | 1.2 |
Category | MIAC Module |
MIAC (dsPIC) component
MIAC - Matrix Industrial Automotive Controller (dsPIC)
FREE
RelayOFF |
Turns off the requested relay given by parameter RelayID, values 1 to 4 | |
RelayID |
The relay to turn off. From 1 to 4. | |
Return |
InputANALOG_10Bit |
InputID |
The input to read. From 1 to 8. | |
Return |
PrintString |
Prints the given character string to the display at the current cursor position and moves the cursor position. | |
Str |
The string to send to the display. | |
Return |
GetKeypad |
Returns the key code of the key that is pressed, otherwise if nothing is pressed then returns 255 | |
Return |
DisplayStart |
Initialise the display ready for use | |
Return |
PrintNumber |
Prints the given number to the display starting at the current cursor position and moves the cursor position. | |
n |
Return |
PrintASCII |
Prints the given character to the display at the current cursor position and increments the cursor position. | |
Char |
ASCII code of the character to print. | |
Return |
DrawRect |
Draws a rectangular box from x1,y1 to x2,y2 | |
x1 |
y1 |
x2 |
y2 |
state |
1=draw pixel, 0=clear pixel | |
Return |
DisplayClear |
Clears the display to white space | |
Return |
RelayON |
Turns on the requested relay given by parameter RelayID, values 1 to 4 | |
RelayID |
The relay to turn on from 1 to 4. | |
Return |
OutputOFF |
Outputs a digital low state on the output requested by parameter TransID (Outputs 1 to 4) | |
TransID |
1 to 4 (Outputs A to D) | |
Return |
DrawPixel |
Draws, or clears, a pixel at point x,y | |
px |
py |
state |
state = 0 clears the pixel, else draws the pixel | |
Return |
OutputON |
Outputs a digital high state on the output requested by parameter TransID (Outputs 1 to 4) | |
TransID |
Return |
InputDIGITAL |
Returns the digital state of the input requested by parameter InputID (Inputs 1 to 8) | |
InputID |
The input number from 1 to 8. | |
Return |
DisplayLight |
Turns the display backlight on or off | |
state |
Return |
InputANALOG |
Returns the 8 bit value for the analogue input requested by parameter InputID (Inputs 1 to 8) | |
InputID |
The input to read from 1 to 8. | |
Return |
Properties |
