Component: DALI Master (Comms: System)
(Redirected from Component: ID 5aefac05 ee5e 4d51 9f31 05281900a97e)
Jump to navigationJump to searchAuthor | MatrixTSL |
Version | 1.0 |
Category | Comms: System |
DALI Master component
A serial based communications protocol designed for controlling lighting, specifically digitally controlled dimmable fluorescent ballasts. DALI requires the signals to be level shifted from VCC and GND to +9.5V - +25.5V and GND. The master component can addess up to 64 individual slaves & up to 16 groups.
COMMSC
DALI Master Example, reads the value of a keypad and sends out DALI commands based on the key pressed, 1 = switch on a slave's light, 2 = switch off a slave's light, 3 = read the slave's light level.
DALI Master Example1
For a DALI Slave example see: Component: DALI Slave (Comms: System)
ReceiveBackwardFrame |
Attempts to receive an 8-bit reply 0 indicates timeout or no reply | |
Return |
Initialise |
Configures the UART serial interface. | |
Return |
Properties |
Serial Properties |
TX Pin |
RX Pin |
Simulation |
API |
