Component: Relay (BL0183) (E blocks 2)
(Redirected from Component: ID 5ed3d626 7e86 4df8 881a c326a2b932ec)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.0 |
Category | E-blocks 2 |
Relay (BL0183) component
The Relay is a digital normally open switch capable of switching much higher voltages and currents than your normal Microcontroller outputs.
When set to HIGH, the LED will light up and the relay will close allowing current to flow.
The peak voltage capability is 250V at 10 amps.
On the simulated component, a green indicator is on when the relay is active.
FREE
Relay1SwitchOff |
Switch off the relay, disconnecting the common pin from the normally open pin. | |
Return |
Relay2SwitchOff |
Return |
Relay2SwitchOn |
Switch on the relay, connecting the common pin to the normally open pin. | |
Return |
Relay1SwitchOn |
Return |
Properties |
Output Mode |
Switch1 |
File:Fc9-type-19-icon.png | Port |
Relay1 Pin |
Relay2 Pin |
