Component: Thermocouple ( MCP960X) (Environmental)
(Redirected from Component: ID 60de8264 7faf 4f77 904e 69bb19909ba8)
Version | 1.1 |
Category | Environmental |
Thermocouple component
Component to interface the MCP960X IC from Microchip. Uses a standard 2-wire I2C interface to connect to the IC and collect the temperature. IC available in different versions to suit different thermocouple types.
SENSORS
Here is a basic example to display both the thermocouple temperature and IC surface temperature.
Sim Demo
ReadReference_Int |
Returns the Reference (IC die) temperature from the last sample as an integer value. Use Sample first, which samples both reference & themocouple temperatures. | |
Return |
ReadRawDataADC |
Returns the thermocouple temperature from the last sample as an integer value in Degrees C. | |
Return |
ReadReference_Float |
Returns the reference (IC die) temperature from the last sample as a floating point. Use Sample first, which samples both reference & themocouple temperatures. | |
Return |
ReadRegister |
Reads a byte from a register | |
Address |
Return |
ReadThermocouple_Int |
Returns the thermocouple temperature from the last sample as an integer value. Use Sample first, which samples both reference & themocouple temperatures. | |
Return |
ReadThermocouple_Float |
Returns the thermocouple temperature from the last sample as a floating point value. Use Sample first, which samples both reference & themocouple temperatures. | |
Return |
WriteRegister |
Writes a byte to a register | |
Address |
Data |
Return |
Initialise |
Configures the I2C bus ready for communications. | |
Return |
