Component: GLCD (ILI9341 SPI) (Graphical Color)
Version 2.0
Category Graphical Color
GLCD (ILI9341 SPI) component
Graphical display component designed to work with the ILI9341 controller IC Based on the ILI9341 16-bit colour graphical controller IC. Uses the SPI CAL component to allow for faster serial display communications.
DISPLAYS
Fc9-u8-icon.png - BYTE Font
Fc9-comp-macro.png BacklightOn
Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-comp-macro.png LCD_Write_Reg
Fc9-u8-icon.png - BYTE data
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-comp-macro.png LCD_Write_Data8
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png Plot
Fc9-comp-macro.png FastPlot
Fc9-comp-macro.png BacklightOff
Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
Fc9-comp-macro.png BPlot
Fc9-comp-macro.png Window
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
Fc9-comp-macro.png DrawCircle
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png Dimensions
Fc9-type-7-icon.png Flip X
Flips the horizontal display axis in hardware.
Fc9-type-7-icon.png Flip Y
Flips the vertical display axis in hardware.
Fc9-conn-icon.png Colour
Fc9-type-7-icon.png Invert Colour
Some display hardware may require colours to be inverted
Fc9-type-7-icon.png Swap Red / Blue
Allows Red and Blue colour channels to be swapped to match the way the display has been wired to the controller IC.
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-7-icon.png Toggle CS
Allows the CS pin to be toggled by the component when communicating with the display. No - Allows for better performace, the display is always enabled Yes - Allows for the display pins to be multiplexed with other functionality without the risk of display corruption
Fc9-type-5-icon.png Chip Select
Chip select pin connection
Fc9-type-5-icon.png D/C
Fc9-type-5-icon.png Reset
Reset pin connection
Fc9-type-5-icon.png LED
Fc9-type-7-icon.png Use Backlight Pin
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Display Method
Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
