Component: Potentiometer (Trimmer) ()
(Redirected from Component: ID 8462ac99 ca8f 429b 953a 36dbe58ada72)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.4 |
Category |
Potentiometer (Trimmer) component
Trim Pot for 0.1mm pitch PCB. With finger dial knob. Pointer colour can be changed from component properties.
Note: The default Vref properties for AVR/Arduino is AREF. If there is no voltage being applied to the AREF pin, then you must change Vref option from AREF to AVCC
BASICIO
