Component: RF 2.4GHz (nRF24L01) (Wireless)
(Redirected from Component: ID 882b6951 9944 48cc 8989 6ebd3d91956f)
Jump to navigationJump to searchAuthor | Matrix Ltd. |
Version | 2.0 |
Category | Wireless |
RF 2.4GHz component
A simple RF communications module based on the 2.4GHz nRF24L01 modules.
COMMSB
ReadRxByte |
Reads a single byte back from the local Rx buffer. | |
Index |
Byte to read, range 0 - 31 | |
Return |
WriteTxByte |
Reads a single byte to the local Tx buffer. | |
Index |
Value |
Return |
FlushRx |
Tells the RF module to flush the contents of the receive buffer. Returns the status from sending the command. | |
Return |
WriteTxFifo |
Writes the contents of the local Tx buffer to the Transmit FIFO. | |
NumBytes |
Number of bytes to write to the FIFO, Range 1 - 32 | |
Return |
FlushTx |
Tells the RF module to flush the contents of the transmit buffer. Returns the status from sending the command. | |
Return |
CheckRX |
Check the Rx FIFO status register for any new data. Returns 0 = No data Returns 1 = New data available | |
Return |
ReadRegister |
Reads a single bytes from the selected register. Directly returns the value read back from the register. | |
Reg |
Register address to access | |
Return |
WriteRegister |
Writes a single byte to the selected register. Returns the status of the write command. | |
Reg |
Value |
Return |
