Component: GLCD (ST7565R) Parallel (Graphical Monochrome)
(Redirected from Component: ID 889a6ac6 12d0 40c0 9882 075ce9801eeb)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.5 |
Category | Graphical Monochrome |
GLCD (ST7565R) Parallel component
Graphical display component designed to work with the ST7565 type monochrome displays. Transfers data using an 8-bit digital data bus.
DISPLAYS
DrawLine |
Draws a line with the current foreground colour from pixel location X1, Y1 to pixel location X2, Y2. | |
X1 |
Y1 |
X2 |
Y2 |
Return |
Plot |
Sets a pixel with the current foreground colour at pixel location X, Y. | |
X1 |
Y1 |
Return |
BPlot |
Sets a pixel with the current background colour at pixel location X, Y. | |
X1 |
Y1 |
Return |
ReadFontStat |
Gets a stat from the selected embedded ASCII font data. | |
Font |
Font selection range: 0 to (NumFonts - 1) | |
Index |
0=SpaceWidth, 1=PixelHeight | |
Return |
ClearDisplay |
This macro clears the display of any previous output by overwriting the entire display with the background colour. | |
Return |
SetBackgroundColour |
Specifies the colour of the foreground | |
PixelColour |
0=White, 1=Black | |
Return |
SetForegroundColour |
Specifies the colour of the foreground. | |
PixelColour |
Return |
Initialise |
The Init macro must be called once to initialise the Graphical LCD display before any other Graphical LCD component macros are called. | |
Return |
Properties |
Dimensions |
Pixel Width |
Width of gLCD canvas measured in pixels. | |
Pixel Height |
Heigt of gLCD canvas measured in pixels. | |
Colour |
Monochrome |
Specifies if the display is capable of colour or monochrome only. | |
Foreground Color |
Specifies the initial foreground color. | |
Background Color |
Specifies the initial background color. | |
Bit Depth |
Color Bit Depth |
Number of bits of colour depth available on the display | |
Red Bit Depth |
Number of bits of Red colour depth on the display | |
Green Bit Depth |
Number of bits of Green colour depth on the display | |
Blue Bit Depth |
Number of bits of Blue colour depth on the display | |
Connections |
Data Pins |
Decides if the 8-bit data bus is controlled using a full port or individual pins. A full port will run faster whereas individual pins allow for more flexibility. | |
File:Fc9-type-4-icon.png | DATAPORT |
CS1 |
Chip select pin | |
RES |
Reset pin | |
A0 |
Address pin to tell the display if we are sending commands or data | |
RD_E |
Enable pin used to clock data into the display | |
WR_RW |
Read Write pin to set the display data mode | |
MODE |
Fonts |
Font Count |
Specifies the number of fonts available to use on the display. | |
Font 0 |
Font |
Font picker to decide which font to use on your display. | |
Character Spacing |
Sets the number of blank pixels between each character when printing text. Default 1. | |
Space Width |
Sets the number of horizontal pixels used to represent a space character. | |
Simulation Mode |
Display Method |
Chooses which method to use when drawing to the gLCD component The bitmap is the more common mode but may run slowly on some machines. The point cloud should run faster but may use more memory. |
