Component: Injector (DS1307 RTC) ()
Version 1.1
Category
Injector (DS1307 RTC) component
Comms data injector to allow simulation of a DS1307 Real Time Clock and RAM.
COMMSA
This example uses the I2C master component combined with the DS1307 injector to simulate an I2C communications bus between the target Microcontroller and the virtual DS1307 device. FC6 Icon.png I2C DS1307 Example The panel displays the current time from the DS1307 RAM which is populated to match the system time.
Fc9-comp-macro.png InitialiseInjector
Fc9-string-icon.png - STRING InjectorName
Fc9-comp-macro.png RxByteCount
Returns the number of bytes currently sat in the receive buffer.
Fc9-comp-macro.png TxByte
Fc9-u8-icon.png - BYTE DataByte
Fc9-comp-macro.png ChangeState
Changes the state for I2C or SPI type comms where the data bytes along are not enough to go on.
Fc9-u8-icon.png - BYTE NewState
Fc9-conn-icon.png DS1307 Injector Settings
Fc9-type-21-icon.png Circular Buffer Size
Fc9-type-16-icon.png Termination Character
Fc9-type-21-icon.png Device Address
Fc9-type-16-icon.png Day Setting
Configures how the day of the week is calculated.
