Component: GLCD (SSD1305) Buffered (SSD1305) (Graphical Monochrome)
Version 1.6
Category Graphical Monochrome
GLCD (SSD1305) Buffered component
Graphical display component based on the SSD1305 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 1K of graphical memory using the microcontroller's RAM memory.
DISPLAYS
Fc9-u8-icon.png - BYTE Font
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png Plot
Fc9-comp-macro.png BPlot
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
Fc9-comp-macro.png DrawCircle
0=White, 1=Black
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png Dimensions
Fc9-type-21-icon.png H Offset
Offset from the edge of the display, default 0.
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-5-icon.png Chip Select (CS)
Chip select pin connection
Fc9-type-5-icon.png Reg Select (RS)
Fc9-type-5-icon.png Data (SD)
Fc9-type-5-icon.png Serial Clock (SCK)
Reset pin connection
Fc9-type-5-icon.png Reset (RST)
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Display Method
