Component: Rectifier (DSP)
(Redirected from Component: ID 939a5d54 28c7 488d af39 46f7c5d2c429)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.2 |
Category | DSP |
Rectifier component
Converts the negative elements of a signal into a mirrored positive signal.
DSP
ControlRectifier |
Enables or disables the rectifier, enabled by default | |
State |
0=Disable, 1=Enable | |
Return |
Rectify |
Collects a single value from the input buffer and outputs a rectified version of the value. | |
Return |
RectifyArray |
Passes an entire buffer through the rectifier and outputs a rectified version of the buffer at the other end | |
Return |
