Component: Thermocouple (MAX31855) (Environmental)
Category Environmental
Thermocouple component
Component to interface the MAX31855 IC from MAXIM. Uses a standard 3-wire SPI interface to connect to the IC and collect the temperature. IC available in different versions to suit different thermocouple types.
SENSORS
Example program showing how to use the Thermocouple component. FC6 Icon.png MAX31855_Example
Fc9-comp-macro.png ReadReference_Int
Returns the reference temperature from the last sample as an integer value in Degrees C.
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png ReadReference_Float
Returns the reference temperature from the last sample as a floating point value in Degrees C.
Fc9-comp-macro.png Sample
Reads the memory of the MAX31855 IC and checks for errors. Must be called before any of the Read functions. Returns: 0=OK, 1=Open Circuit, 2=Short GND, 3=Short VCC
Fc9-comp-macro.png ReadThermocouple_Int
Returns the thermocouple temperature from the last sample as an integer value in Degrees C.
Fc9-comp-macro.png ReadThermocouple_Float
Returns the thermocouple temperature from the last sample as a floating point value in Degrees C.
Fc9-comp-macro.png Initialise
Configures the SPI bus ready for communications.
Fc9-conn-icon.png Thermocouple Properties
Fc9-type-16-icon.png Thermocouple Type
Specified at the end of the MAX part number MAX31855X where X is the Thermocouple type. Selects which type of thermocouple the IC works with.
Fc9-conn-icon.png SPI Properties
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-conn-icon.png Simulation
