Component: GLCD (SSD1963) Parallel (Graphical Color)
Category Graphical Color
GLCD (SSD1963) Parallel component
Graphical display component designed to work with the SSD1963 controller IC Based on the SSD1963 16-bit colour graphical controller IC.
DISPLAYS
Without Touchscreen
Example using a 4.3" TFT Display using the SSD1963 Graphical LCD Controller. FC6 Icon.png GLCD 4.3 Example using a 7" TFT Display using the SSD1963 Graphical LCD Controller. FC6 Icon.png GLCD 7
With Touchscreen
Example using the XPT2046 touchscreen driver IC with a 4.3" TFT Display using the SSD1963 Graphical LCD Controller. FC6 Icon.png GLCD 4.3 Touch Example using the XPT2046 touchscreen driver IC with a 7" TFT Display using the SSD1963 Graphical LCD Controller. FC6 Icon.png GLCD 7 Touch
Fc9-u8-icon.png - BYTE Font
Fc9-comp-macro.png BacklightOn
Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
Fc9-comp-macro.png FastBPlot
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png Plot
Fc9-comp-macro.png FastPlot
Fc9-comp-macro.png BacklightOff
Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
Fc9-comp-macro.png BPlot
Fc9-comp-macro.png Window
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
Fc9-comp-macro.png DrawCircle
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png Dimensions
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-16-icon.png DataMode
Configures how the displays data pins are connected. Port uses a single port byte allowing for high speed. Individual pins allow for any combination of pins allowing for flexibility.
File:Fc9-type-19-icon.png Data Port
Microcontroller port pins to use to pass 8-bit parrallel data to the graphical display
Fc9-type-5-icon.png Chip Select
Chip select pin connection
Fc9-type-5-icon.png Write
Write pin connection
Fc9-type-5-icon.png Read
Read pin connection
Fc9-type-5-icon.png Register Select (RS)
Fc9-type-5-icon.png Reset
Reset pin connection
Fc9-type-7-icon.png Use Backlight Pin
Controls if the backlight is controlled using an I/O pin or fixed to be always on by the circuitry.
Fc9-conn-icon.png Display Properties
Fc9-type-7-icon.png FlipX
Flips the horizontal axis
Fc9-type-7-icon.png FlipY
Flips the vertical axis
Fc9-type-16-icon.png TFT Colour Bits
Sets the colour depth of the display so the SSD1963 controller IC outputs the correct colour sequences.
Fc9-type-21-icon.png OffsetX
Pixel offset on the x axis
Fc9-type-21-icon.png OffsetY
Pixel offset on the y axis
Fc9-conn-icon.png Display Refresh Rate
Fc9-type-21-icon.png PLL Multiplier
Controls the refresh rate of the display. Range 0 - 255
Fc9-type-21-icon.png PLL Divider
Controls the refresh rate of the display. Range 0 - 15
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Display Method
