Component: Base 64 (Storage)
Category Storage
Base 64 component
Component to allow base 64 encoding and decoding. Sometimes when communicating raw binary data it is useful to perform base 64 encoding to ensure that none of your data bytes trigger any escape codes or other special case conditions. Base64 converts your binary data into readable data using standard ASCII characters so you can be fairly certain that the data you send is the same as the data that is received.
COMMSC
Here is a basic example that shows how to convert data into base64 encoded data and visa versa. FC6 Icon.png Base64 Tests
Fc9-comp-macro.png Encode
Encodes an array of bytes into a base64 encoded string
Fc9-u8-icon.png - BYTE BinaryData
Raw binary data array you wish to encode
Fc9-u16-icon.png - UINT ByteCount
Number of bytes of data to encode
Fc9-comp-macro.png Decode
Decodes a base64 encoded string into an array of bytes. Populates the BinaryData parameter array with the decoded data. Returns the number of decoded data bytes.
Variable to hold the decoded binary data
Fc9-string-icon.png - STRING Base64Data
Data string you wish to decode
