Component: LED Cube (Misc Circuit)
(Redirected from Component: ID b4f41fb0 9335 4a8f a41d 284a8cfc31b5)
Jump to navigationJump to searchAuthor | Ben Rowland 2014 |
Version | 1.0 |
Category | Misc Circuit |
LED Cube component
LED Cube component for driving 3D arrays of LEDs. A typical cube could consist of 4x4x4 or 8x8x8 but does not necessarily need to be a cuboid.
BASICIO
Clear |
Clears the contents of the display to 0x0000 | |
SwitchBuffers |
0=DoNotSwitch 1=SwitchAutomaticallyWhenDone | |
Return |
RotateShellXZ |
Shifts the contents of the display by the number of vertices specified | |
Direction |
Shell |
Return |
RotateShellXY |
Direction |
Shell |
Return |
DrawLine |
Draws a basic 3D line onto the LEDs | |
X1 |
Y1 |
Z1 |
X2 |
Y2 |
Z2 |
Colour |
SwitchBuffers |
Return |
RotateShellYZ |
Direction |
Shell |
Return |
ConvRGBToColour |
Converts RGB values into a single UINT colour parameter to use with other functions. | |
Red |
Green |
Blue |
Return |
ConvColourToRGB |
Reads the individual RGB colour values from a single UINT colour value. Return Index: 0=Red, 1=Green, 2=Blue | |
Colour |
Return |
GetColour |
Reads the colour value from a single pixel in the active buffer as a 16-bit value. Bits 0-4 = Red Bits 5-10 = Green Bits 11-15 = Blue | |
X |
Y |
Z |
Return |
ResetRotations |
Resets the rotation count variables allowing for a new rotation to be started | |
Return |
Initialise |
Sets up the data memory and draws the simulated LED cube on the panel. | |
Return |
Properties |
LEDs |
Width (X) |
The number of LEDs wide | |
Depth (Y) |
The number of LEDs deep | |
Height (Z) |
The number of LEDs tall | |
LED Count |
Number of LEDs required by the component | |
LED Type |
Common Type |
Wiring Order |
Specifies the order of the wiring of the LEDs from lowest bit to highest | |
Driver Pre Delay |
Number of micro seconds to wait between switching off the driver and clocking out the new signals. Used to remove any ghosting effects visible on the display due to slow driver switch off times. | |
Driver Post Delay |
Connections |
Clock Pin |
File:Fc9-type-19-icon.png | Data Port |
File:Fc9-type-19-icon.png | Enable Port |
Simulation |
LED Size |
Size of each LED on the panel | |
Spacing |
Number of units of spacing between each LED | |
Transparent |
If set to yes then a LED which is completely switched off will be set to transparent, If set to no then the LED will be shown as black. | |
Toggle Pins |
Determines if the pins are toggled as part of the PWMTimer macro during simulation. During simulation you probably don't want the pins toggling as it will slow down simulation. The only exception may be if you want to see the signals in the scope window. Does not effect the compiled embedded code. |
