Component: Switch Array Template (Switches)
Author Matrix Ltd.
Version 2.0
Category Switches
Switch Array Template component
A base component for creating an evenly spaced array of switches. Each will be connected to sequential pins of a given I/O port. Set target object to point at any standard switch component to change the type of switch used by the array.
BASICIO
Here is an example Flowcode program to read the values of a switch array. FC6 Icon.png Switch Array Here is a schematic of how to connect a basic switch to a microcontroller pin.
The resistors are required for correct operation because when a microcontroller's input pin is essentially connected to nothing it will pick up noise in the environment and provide inconsistent readings. This state is referred to as floating i.e. the pin is floating. To test this remove the resistors (if possible) and touch the unconnected switch pins with your finger the output LEDs from the example file above will toggle on and off at high speed.
(5V / 11K) * 10K = 4.54545V
Fc9-comp-macro.png ReadState
Read the state of the switch at the given index.
Fc9-u8-icon.png - BYTE Index
The switch to read the status of.
Fc9-comp-macro.png WaitUntilHigh
Pause the program until the switch at the given index is turned on.
Index of the switch to wait for.
Fc9-comp-macro.png ReadAll
Reads all of the switches at once, returning a byte containing one bit per switch.
Fc9-comp-macro.png GetHandle
Retrieves the object handle of the switch component at the given index.
Fc9-comp-macro.png WaitUntilLow
Fc9-type-21-icon.png Count
The number of LEDs in the array from 1 to 8.
Fc9-type-16-icon.png Input Mode
Choose a single port for all LEDs - pins are allocated in sequence from pin 0 - 7 ...or choose 'Custom pins' to assign each switch individually.
File:Fc9-type-19-icon.png Port
Fc9-type-16-icon.png Polarity
Active High = LEDs light when the chosen chip pin is ON Active Low = LEDs light when the chosen chip pin is OFF
Fc9-type-14-icon.png Debounce
Time in milliseconds allowed for the pin to settle following a change of state.
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Operation
Sets whether switches toggle or are press/release. NB) This option can only be set when the original target includes this option.
Fc9-type-16-icon.png Alignment
Which 3D axis to align the copies along.
Fc9-type-15-icon.png Spacing
The distance between LEDs in the array. LEDs will be spaced symmetrically around the component centre. Use a negative value to reverse the order of the LEDs.
Fc9-type-7-icon.png Reverse
Whether to reverse the order of the switches.
Fc9-type-16-icon.png Show Labels
Whether to show labels giving each switch's pin connection.
Fc9-type-1-icon.png Label color
Color of the port and pin labels
Fc9-conn-icon.png Shape
Fc9-type-17-icon.png Target Switch
To use a custom switch design... - Drag any switch component onto the panel, or create your own using the 'Switch base' - Give your new switch a memorable name. - Choose the new switch in this property; copies will be made to fill the array, and the original is hidden. When unconnected, it will use a default 'basic switch'.
