Component: Switch (Toggle, PCB) ()
Author | Matrix Ltd |
Version | 1.1 |
Category |
Switch (Toggle, PCB) component
Miniature toggle switch with metal tang. Pins for PCB mounting.
BASICIO
Switch
(5V / 11K) * 10K = 4.54545V
