Component: Input Digital (DSP)
(Redirected from Component: ID c73d493a b6a0 4dbe b4b5 79648f67d11e)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.2 |
Category | DSP |
Input Digital component
Allows the values from a buffer to be assigned. Either a value at a time or from an array. The input signal would usually take the form of an ADC reading or raw data values.
DSP
Here is a basic example demonstrating how to pass a value into the DSP chain.
Delay
The input value in the example uses an ADC reading but this can be taken from anything such as a reading from a CSV file on a SD card or a value passed by a sensor on a I2C bus etc.
AddByte |
Adds a single byte value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1. | |
Data |
Return |
AddLong |
Adds a single long value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1. | |
Data |
Return |
AddInt |
Adds a single integer value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1. | |
Data |
Return |
AddFloat |
Adds a single float value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1. | |
Data |
Return |
Properties |
Buffer Size |
Number of individual elements the buffer can store, default 1. | |
Buffer Type |
Sets the buffer data type, data is automatically scaled to fit and make full use of the data type. |
