Component: Barometer (DPS310) (Environmental)
Category Environmental
Barometer (DPS310) component
A barometric air pressure sensor with high accuracy and low current consumption. Capable of sensing air pressure and temperature. Based on an I2C bus connection.
SENSORS
Fc9-comp-macro.png ReadTemperature
Reads the temperature measurement from the last SampleSensor macro
Fc9-comp-macro.png ConfigurePressure
Configures the pressure sensor sample rate and over sampling count
Fc9-u8-icon.png - BYTE Rate
Range: 0-7, 0=1Hz, 1=2Hz, 2=4Hz etc
Fc9-u8-icon.png - BYTE Oversample
Range: 0-7, 0=1Samples, 1=2Samples, 2=4Samples etc
Fc9-comp-macro.png ConfigureTemperature
Configures the temperature sensor sample rate and over sampling count
Fc9-comp-macro.png ReadPressure
Reads the pressure measurement from the last SampleSensor macro
Fc9-comp-macro.png SetMode
Sets the operational mode of the sensor to be continous or one shot
Fc9-u8-icon.png - BYTE Mode
Fc9-comp-macro.png ReadAltitude
Reads the pressure measurement from the last SampleSensor macro and converts the pressure reading into an altitude reading.
Fc9-comp-macro.png SampleSensor
Checks to see if new data is available for temperature or pressure and collects it. Returns 0 if no new data is available Returns 1 for pressure, 2 for temperature and 3 for both.
Fc9-comp-macro.png ReadRegister
Reads a byte from a register
Fc9-comp-macro.png WriteRegister
Writes a byte to a register
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png Initialise
Starts up the I2C ready to communicate with the sensor. Sets the selected rates and operational mode. Returns 1 if the sensor has been found and initialised.
Fc9-conn-icon.png Device Settings
Fc9-type-16-icon.png Device Address
Fc9-type-16-icon.png Measurement Rate
Fc9-type-16-icon.png Oversample Rate
Fc9-type-16-icon.png Operational Mode
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Simulation
No: Provides simulation using the panel component sliders. Yes: Communicates via an API Slave device to real world hardware, shows the results using the panel component sliders.
