Component: Marking control (Misc)
(Redirected from Component: ID d750dde7 ddbc 4d66 bea1 5a5ae94dfa70)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.1 |
Category | Misc |
Marking control component
A control to draw markings on any component
MODELS
DrawStripY |
Draw the marks on the readout Set up the position and range with SetRange() and SetSpan() | |
OffsetX |
Offset to add to X | |
Return |
SetTarget |
Sets the target image to draw on | |
Target |
AreaX |
The X area to draw on | |
AreaY |
The Y area to draw on | |
AutoCreate |
Set true to auto-create the graphic | |
Return |
DrawStripX |
OffsetY |
Offset to add to Y | |
Return |
BoundRange |
Bounds a range to be between RangeStart and RangeEnd | |
Range |
The unbounded range | |
Return |
DrawArc |
Draw the marks on the readout Set up the position and range with SetRange() and SetArc() | |
Radius |
Scale of the radius to draw at | |
Return |
SetAngles |
Sets the min-max angles to draw on the dial Used for setting the needle Defaults are 135 and -45 | |
Start |
End |
Return |
SetShow |
Decides on the presentation of the dial | |
ShowNumbers |
True to show numbers on the dial, else false | |
ShowMarks |
Show marks | |
Return |
CalcScaleRange |
Decide the range value for a 0->1 value Returned value may be out of range | |
ScaledRange |
Return |
CalcAngRange |
Decide the range value for an angle Returned value may be out of range | |
AngleDegrees |
Return |
CalcScale |
Decide the scale (0->1) to display at given a range value | |
RangeVal |
Return |
SetMarks |
Marks |
Number of marks on the dial | |
Subs |
Number of marks before a 'main' mark - can be zero | |
Return |
ClearArea |
Clears the draw area | |
Return |
SetRange |
Sets the min-max range to draw on the dial Used for setting the needle | |
Start |
End |
Return |
SetGaps |
Sets the min-max of the span to draw on the X/Y marks Defaults are 0 and 1 | |
Start |
End |
Return |
SetJustify |
RAlign |
True for right/top/outer alignment | |
Return |
CalcAngle |
Decide the angle to display at given a range value | |
RangeVal |
Return |
Properties |
