Component: Temp / Humidity (Grove 101020212) (101020212) (Environmental)
(Redirected from Component: ID eca89720 1386 4589 ab75 6c0425162b91)
Version | 2.0 |
Category | Environmental |
Temp / Humidity (Grove 101020212) component
Humidity and temperature sensor using an SHT31 IC connected via I2C. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
SENSORS
GetTemperatureReal |
Return temperature reading as a float value in degrees C | |
Return |
GetTemperatureData |
Returns the raw register pair value | |
Return |
GetTemperatureInt |
Return temperature reading as an integer value in degrees C | |
Return |
GetHumidityInt |
returns the relative Humidity reading as an integer value | |
Return |
GetHumidityReal |
returns the Humidity reading as a float value | |
Return |
GetHumidityData |
Return |
