Component: LED Matrix (HT16K33) (LEDs)
Version 2.0
Category LEDs
LED Matrix component
LED Matrix component designed to work using a HT16K33 LED driver IC. Can drive up to 16 x 8 (128) LEDs. Includes support for 8x16 Backpack, 16x8 Featherwing, 8x8 Backpack and Custom.
BASICIO
Example to display a bitmap image on the LED matrix using the Bitmap Drawer component.
File:HT16K33 Bitmap.zip
Fc9-comp-macro.png DisplayString
Prints an ASCII string onto the LED Matrix a column at a time.
Data string to display on the LEDs
Fc9-u16-icon.png - UINT Animation_Delay
Delay in milliseconds between writing to the next column
Fc9-u8-icon.png - BYTE Leadout
Allows the text to scroll completely off the display before returning 0=No, 1=Yes
Fc9-u8-icon.png - BYTE Add_Spaces
Add spaces between each ASCII character 0=No, 1=Yes
0=Normal, 1=Rotated 90 Degrees
Fc9-comp-macro.png SetBrightness
Configures the brightness of the LEDs by varying the On portion of the duty.
Fc9-u8-icon.png - BYTE Brightness
Range: 0-15 - 0 = Min Brightness, 15 = Full Brightness
Fc9-comp-macro.png ShiftColumns
Shifts the columns one place left or right. Used for things like displaying scrolling text.
Fc9-u8-icon.png - BYTE Direction
0 = Shift Left, 1 = Shift Right
Fc9-comp-macro.png ClearLEDs
Sets all of the LEDs in the matrix to the off state.
Fc9-comp-macro.png WriteLED
Allows a single LED to be controlled using the basic column / row coordinate system. Each column is comprised of 8 rows.
Fc9-u8-icon.png - BYTE Column
Range: 0-15
Fc9-u8-icon.png - BYTE Row
Range: 0-7
Fc9-u8-icon.png - BYTE Data
0 = LED Off, 1 = LED On
Fc9-comp-macro.png WriteLEDXY
Allows a single LED to be controlled using a more standard X, Y coordinate system. 0,0 refers to the bottom left hand LED. Only works with the fixed display modules, custom module not supported.
Fc9-u8-icon.png - BYTE X
X coordinate. Range: 0-15
Fc9-u8-icon.png - BYTE Y
Y coordinate. Range: 0-15
Fc9-u8-icon.png - BYTE State
State 0=Off, 1=On
Fc9-comp-macro.png WriteCommand
Writes a command.
Fc9-u8-icon.png - BYTE Command
Fc9-comp-macro.png WriteColumn
Allows a single column of 8 LEDs to be controlled in a single action.
Range: 0-15
Data to display on the column of LEDs
Fc9-comp-macro.png WriteRegister
Writes a value to a register.
Fc9-u8-icon.png - BYTE Value
Fc9-comp-macro.png Initialise
Configures the I2C peripheral and sets up the HT16K33 IC ready to drive the LEDs.
Fc9-type-16-icon.png Display Module
Selects the layout of the module you are controlling. Several modules are available in pre wired formats to provide an off the shelf LED matrix.
Fc9-type-14-icon.png LED Count
Total number of LEDs in the component
Fc9-type-16-icon.png Slave Address
Sets the software device slave address. Must be configured to match the wiring of the three hardware address pins.
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Colours
Fc9-type-1-icon.png On Color
Simulated colour of the LEDs when switched On
Fc9-type-1-icon.png Off Color
Simulated colour of the LEDs when switched Off
Fc9-type-1-icon.png PCB Colour
Fc9-type-1-icon.png Label Colour
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Simulation Type
Sets the simulation type. Component GUI allows the object on the panel to reflect what the reakl life LED matrix should do. I2C Injector allows the I2C communications to be simulated via injectors.
Fc9-conn-icon.png GUI
Fc9-type-15-icon.png Column Spacing
Simulation column spacing
Fc9-type-15-icon.png Width
Simulation LED width
Fc9-type-15-icon.png Row Spacing
Simulation row spacing
Fc9-type-15-icon.png Height
Simulated LED height
Fc9-type-15-icon.png Depth
Simulated LED Depth (3D environments only)
Fc9-type-16-icon.png LED Shape
Simulated LED basic shape
