Component: Real Time Clock (Internal, DS1307, DS3231, DS3232) (Storage)
Version 2.2
Category Storage
Real Time Clock (Internal, DS1307, DS3231, DS3232) component
A Real Time Clock component allowing things like clocks and timers to easily be created. Compatible with the internal RTCC module and external DS1307, DS3231 or DS3232 RTC ICs.
FREE
FC6 Icon.png RTC DS1307 DS3231 Example.fcfx
Example showing how to retrieve and display the time using bytes or string RTC component.
Fc9-comp-macro.png SetSecs
Sets the seconds as a binary value 0-59. Does not currently simulate.
Fc9-u8-icon.png - BYTE Seconds
Range 0-59
Fc9-u8-icon.png - BYTE WhichClock
0=Time, 1=Alarm1 DS3231
Fc9-comp-macro.png SetYear
Sets the year as a binary value 0-99. Does not currently simulate.
Fc9-u8-icon.png - BYTE year
Range 0-99
Fc9-comp-macro.png GetDateString
Reads the current date from the RTC and returns it formatted as a string. e.g. DD:MM:YY
Fc9-u8-icon.png - BYTE USformat
0="DD/MM/YY", 1="MM/DD/YY"
Fc9-comp-macro.png SQWandINTcontrol
Allows a square wave output to be generated by the DS1307 and DS3231 ICs. Also allows the DS3231 interrupts to be configured via the INT/SQW pin. This function doesn't currently simulate.
Fc9-u8-icon.png - BYTE SquareWaveEnable
0 = Square Wave Output Disabled / 1 = Square Wave Output Enabled
Fc9-u8-icon.png - BYTE FrequencySelect
Controls the output frequency of the square wave, Range 0-3, Refer to the device datasheet for frequencies
Fc9-u8-icon.png - BYTE InterruptEnable
Only Available on DS3231 and when SQW is disabled. Range 0-3
Fc9-comp-macro.png GetSecs
Gets the seconds of the current time as a binary value 0-59. Simulation returns system time.
Fc9-comp-macro.png GetHours
Gets the hours of the current time as a binary value 0-11 or 0-23. Simulation returns system time.
0=Time, 1=Alarm1 DS3231, 2=Alarm2 DS3231
Fc9-comp-macro.png GetYear
Gets the year as a binary value 0-99. Simulation returns system date.
Fc9-comp-macro.png GetWeekDay
Gets the day of the week as a binary value 1-7. This function doesn't currently simulate.
Fc9-comp-macro.png SetRamDS3232
Sets the value of one of the free RAM locations on the DS3232 device
236 RAM Locations. Range: 0 to 235
Fc9-u8-icon.png - BYTE Data
Data value. Range 0 to 255
Fc9-comp-macro.png SetRamDS1307
Sets the value of one of the free RAM locations on the DS1307 device
56 RAM Locations. Range: 0 to 55
Fc9-comp-macro.png SetWeekDay
Sets the day of the week as a binary value 1-7. This function doesn't currently simulate.
Fc9-u8-icon.png - BYTE Day
Range 1-7
Fc9-comp-macro.png SetMonth
Sets the month as a binary value 1-12. Does not currently simulate.
Fc9-u8-icon.png - BYTE month
Range 1-12
Fc9-comp-macro.png SetHours
Sets the hours as a binary value 0-23. Does not currently simulate.
Fc9-u8-icon.png - BYTE Hours
Range 0-23
Fc9-u8-icon.png - BYTE Mode
0=24 Hour Clock, 1=12 Hour Clock
Fc9-comp-macro.png SetMins
Sets the minutes as a binary value 0-59. Does not currently simulate.
Fc9-u8-icon.png - BYTE Minutes
Range 0-59
Fc9-comp-macro.png GetMins
Gets the minutes of the current time as a binary value 0-59. Simulation returns system time.
Fc9-comp-macro.png SetDate
Sets the date as a binary value 1-31. Does not currently simulate.
Fc9-u8-icon.png - BYTE date
Range 1-31
Fc9-comp-macro.png GetTimeString
Reads the current time from the RTC and returns it formatted as a string. e.g. HH:MM:SS
Fc9-u8-icon.png - BYTE IncludeSeconds
0=Dont Include Seconds, 1=Include Seconds
Fc9-comp-macro.png GetAmPm
Checks to see if the time is currently AM or PM for 12 hour clock mode. Simulation returns system time. 0 = AM / 1 = PM
Gets the date as a binary value 1-31. Simulation returns system date.
Fc9-comp-macro.png GetRamDS3232
Gets a byte of RAM from the free memory on the DS3232 device.
Fc9-comp-macro.png GetRamDS1307
Gets a byte of RAM from the free memory on the DS1307 device.
Fc9-comp-macro.png GetMonth
Gets the month as a binary value 1-12. Simulation returns system date.
Fc9-comp-macro.png Initialise
Initialises the RTC component ready for operation.
Fc9-type-16-icon.png RTC Module
Fc9-type-21-icon.png I2C Address
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png API
