Component: WLAN ESP32 (ESP32) (Comms: Networking)
Author Matrix Ltd.
Version 2.4
Category Comms: Networking
WLAN ESP32 component
Wireless LAN component designed to work with ESP32 modules
FREE
Here is an example Flowcode program to send analogue data to a html web page. The web page is set up to refresh every second Instructions on how to change the refresh rate and access the web page is explained within the example file. FC6 Icon.png ESP Webpage
Fc9-comp-macro.png ReadIPString
Collects the local IP address and returns it as an ASCII string. e.g. "192.168.0.1"
Fc9-comp-macro.png SocketConnect
Fc9-string-icon.png - STRING Address
Fc9-u16-icon.png - UINT Port
Fc9-comp-macro.png SocketListen
Listen on, or bind, local port to already opened socket. Returns 1 if OK, 0 if fail
Fc9-comp-macro.png ReadSSIDFromScan
Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first.
Fc9-u8-icon.png - BYTE Index
SSID Index
Fc9-comp-macro.png CreateAccessPoint
Sets up the wireless LAN module into AP mode to host a wireless network. Other WIFI enabled devices can then connect to the module. Returns 1 for success.
Fc9-string-icon.png - STRING SSID
Name of the wireless network to create
Fc9-string-icon.png - STRING Password
Password used to gain access to the network
802.11 Channel Range 1-14
Fc9-u8-icon.png - BYTE Encryption
0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
Collects a single byte from the local IP address. For example 192.168.0.1 Index = 3 : Return = 192 / Index = 0 : Return = 1
Range: 0 to 3 Where 3 = the first number and 0 = the last number
Fc9-comp-macro.png SocketWrite
Fc9-string-icon.png - STRING Buffer
Fc9-u16-icon.png - UINT Size
Fc9-comp-macro.png Disconnect
Attempts to disconnect from the SSID.
Fc9-comp-macro.png ReadSignalStrengthFromScan
Collects the signal strength from the last SSID Scan. The ScanForSSID macro must be called first. Value returned is in negative dB, smaller value = better signal
SSID Index
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png ReadEncryptionModeFromScan
Collects one of the encryption modes from the last SSID Scan. The ScanForSSID macro must be called first. 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
SSID Index
Fc9-comp-macro.png ConnectToSSID
Attempts to connect to the given SSID and Key values. Returns 1 if the SSID has been connected.
Fc9-string-icon.png - STRING Key
Fc9-u8-icon.png - BYTE Timeout
Number of seconds to wait for the connection, default 20
Fc9-comp-macro.png SocketOpen
Returns 1 if socket sucessfully opened
Fc9-comp-macro.png SocketClose
Fc9-comp-macro.png Uninitialise
Shuts down the WiFi system for low power operation. Returns 1 if successful Returns 0 if not
Fc9-comp-macro.png AcceptOpen
Returns 1 if there is an incoming connection on the listening port
Fc9-comp-macro.png ScanForSSID
Checks for wireless networks in the local area which are broadcasting their SSID. Must not be connected to a network to allow this to function. Returns the number of wireless networks found, max 8.
Fc9-comp-macro.png SocketRead
Fc9-comp-macro.png AcceptClose
Close the socket associated with the Accepted incoming connection
Fc9-comp-macro.png Initialise
Initialise the WiFi system Returns 1 if successful Returns 0 if not
Fc9-type-7-icon.png Verbose Debug
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Network Interface
List of network interfaces connected to the PC. Sets which interface we are communicating via.
Generate Console Data
