Component: MIAC NXT / ECU (MIAC Module)
Version 1.1
Category MIAC Module
MIAC NXT / ECU component
Component to drive the MIAC NXT / MIAC ECU range of hardware.
FREE
Fc9-comp-macro.png TransistorOutputState
Allows one of the high speed transistor outputs ( A - F ) to be pulled to GND, Pulled to +V or disabled.
Range: 1 - 6 where 1=A / 2=B / 3=C / 4=D / 5=E / 6=F
Fc9-u8-icon.png - BYTE State
0 = Pull to Ground / 1 = Pull to +V / 2 = DisableOutput
Fc9-comp-macro.png DisplayPrintFormattedNumber
Fc9-u32-icon.png - ULONG Number
Enter the number or variable to print to the display
Fc9-bool-icon.png - BOOL Format
0 = Signed, 1 = Unsigned
Fc9-comp-macro.png DisplayPrintFloat
Prints a formatted floating point number to the display
Fc9-f32-icon.png - FLOAT Number
Fc9-u8-icon.png - BYTE DecimalPoints
Number of decimal points to display
Fc9-comp-macro.png DisplayGetCursorPosition
Gets the current pixel position of the cursor within the coordinate space
Fc9-u8-icon.png - BYTE Axis
0=X, 1=Y
Fc9-comp-macro.png ReadTransistorOutputCurrent
Reads the current for one of the transistor outputs ( A - F ) Returns the current as a floating point number in amps
Range: 1 - 6 - 1=A / 2=B / 3=C / 4=D / 5=E / 6=F
Fc9-comp-macro.png RelayOutputState
Allows one of the relay outputs ( Q1 - Q2 ) to be switched on or off.
Range: 1 - 2 Where 1=Q1 / 2=Q2
Fc9-bool-icon.png - BOOL State
0 = Relay Open Circuit / 1 = Relay Closed Circuit
Fc9-comp-macro.png ReadUSBConnected
Checks to see if there is an active USB cable connected to the MIAC. Returns 1 if there is a USB cable present, otherwise returns 0.
Fc9-comp-macro.png InputAnalogByte
Reads one of the input channels ( IN1 - IN8 ) as an analogue value with range 0-255
Range: 1 - 8
Fc9-comp-macro.png ReadKeypad
Directly reads the keypad for any current switch inputs. Returns the keypad switch states as a 9-bit value. Bit0 = TopLeft, Bit1 = TopMiddle, Bit2 = TopRight, Bit3 = CenterLeft, etc..
Fc9-comp-macro.png ReadEEPROM
Read a single byte from the EEPROM.
Fc9-u16-icon.png - UINT Address
Fc9-comp-macro.png DisplayClear
Clears all text from the display
Fc9-comp-macro.png DisplayPixel
Sets or clears a pixel at location X, Y.
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
0=Off / 1=On
Fc9-comp-macro.png WriteEEPROM
Write a single byte to a location in the EEPROM.
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png DisplayClearLine
Clears a single line of text from the display
Fc9-u8-icon.png - BYTE Line
Line to clear. Range 0 to CharacterHeight - 1
Fc9-comp-macro.png DisplayPrintASCII
Prints a single ASCII character to the display
Holds an ASCII value e.g. 'A'
Fc9-comp-macro.png TransistorPWMDuty
Sets the PWM duty on the selected channel
Range: 1-4 Where 1=A / 2=B / 3=C / 4=D
Fc9-bool-icon.png - BOOL EnableOrState
1 = Enable / 0 = State
Fc9-u16-icon.png - UINT Duty
Range: 0 - 65535
Fc9-comp-macro.png DisplayPrintString
Prints a string of ASCII characters to the display
Enter the text or variable to print to the display
Fc9-comp-macro.png TransistorPWMEnable
Enables or disables PWM on the selected channel
PWM on Enable Pin or State Pin - 1 = Enable / 0 = State
Fc9-bool-icon.png - BOOL OnOrOff
1 = Enabled / 0 = Disabled
Fc9-comp-macro.png DisplayCursor
Moves the current pixel position of the cursor within the coordinate space
Sets the pixel position on the X plane, 0 is the left most pixel
Sets the pixel position on the Y plane, 0 is the top most pixel
Fc9-comp-macro.png InputDigital
Reads one of the input channels ( IN1 - IN8 ) as a digital value with range 0-1
Range: 1 - 8
Fc9-comp-macro.png DisplayPrintNumber
Prints a number to the display as an ASCII string
Fc9-s16-icon.png - INT Number
Fc9-comp-macro.png InputAnalogInt
Reads one of the input channels ( IN1 - IN8 ) as an analogue value with range 0-4095
Range: 1 - 8
Fc9-comp-macro.png Initialise
Starts up the MIAC IO and display.
Fc9-conn-icon.png Transistor Output PWM Settings
Fc9-type-16-icon.png Prescaler Divide
Allows the user to change the number of program cycles per PWM cycle count. Note that all PWM channels based on the same timer will share the same prescaler.
Fc9-type-14-icon.png Period Register
Allows the user to change the number of counts for the whole PWM period. Note that all PWM channels based on the same timer will share the same period overflow. PIC/AVR Range: 0 - 255 16-bit PIC Range: 0 - 65535
Fc9-type-16-icon.png PWM Timer
Timer associated with PWM to drive the output. Warning - All PWM channels linked to the same timer will share the same period and prescaler settings.
Fc9-type-15-icon.png Frequency (Hz)
Fc9-conn-icon.png Display Settings
Fc9-type-16-icon.png Font
Fc9-conn-icon.png Pin Connections
Fc9-conn-icon.png CAN (2 x Internal + 1 x External MCP2515)
Fc9-type-5-icon.png C1 TX
Fc9-type-5-icon.png C1 RX
Fc9-type-5-icon.png C2 TX
Fc9-type-5-icon.png C2 RX
Fc9-type-5-icon.png C3 MOSI
Fc9-type-5-icon.png C3 MISO
Fc9-type-5-icon.png C3 SCK
Fc9-type-5-icon.png C3 CS
Fc9-type-5-icon.png C3 INT
Fc9-type-5-icon.png C3 RES
Fc9-conn-icon.png LIN
Fc9-type-5-icon.png LIN TX
Fc9-type-5-icon.png LIN RX
Fc9-type-5-icon.png LIN Enable
Fc9-conn-icon.png Bluetooth RN4678
Fc9-type-5-icon.png BT TX
Fc9-type-5-icon.png BT RX
Fc9-type-5-icon.png BT Reset
Fc9-conn-icon.png Wifi ESP12S
Fc9-type-5-icon.png Wifi TX
Fc9-type-5-icon.png Wifi RX
Fc9-type-5-icon.png Wifi Reset
Fc9-conn-icon.png Ethernet W5500
Fc9-type-5-icon.png ETH MOSI
Fc9-type-5-icon.png ETH MISO
Fc9-type-5-icon.png ETH SCK
Fc9-type-5-icon.png ETH CS
Fc9-type-5-icon.png ETH INT
Fc9-type-5-icon.png ETH RES
