Component: USB MIDI (Comms: USB)
(Redirected from Component: ID fdceef06 919a 405b 8d0b 6118cd0e104c)
Jump to navigationJump to searchAuthor | Matrix Ltd. |
Version | 1.3 |
Category | Comms: USB |
USB MIDI component
Component to create and communicate using a standard MIDI connection. Compatible with simulation and USB enabled microcontroller devices. Currently only compatible with the 16-bit PIC range of devices.
COMMSC
SendPitchChange |
Sends out a pitch change command on the specified channel. | |
Channel |
Channel to send the pitch change to | |
Pitch_Change |
New pitch value to use, Default 0x2000 | |
Return |
SendNoteOff |
Sends a note off command using the channel, note and velocity specified. | |
Channel |
Note |
Velocity |
Return |
SendControl |
Sends a control command using the channel, controller and value specified. | |
Channel |
Controller |
Value |
Return |
SendNoteOn |
Sends a note on command using the channel, note and velocity specified. | |
Channel |
Note |
Velocity |
Return |
SendPolyPressure |
Sends a note press with an associated polyphonic pressure value. | |
Channel |
Note |
Pressure |
Return |
ReadData |
Reads a byte from the last received MIDI message | |
Idx |
Byte to read 0-3 | |
Return |
SendPatch |
Channel |
Instrument |
Return |
SendChannelPressure |
Channel |
Pressure |
Return |
Initialise |
Starts up the USB communications and attempts to enumerate. Returns 0 for a successful startup or 255 for a enumeration timeout. | |
Return |
