Component: Indicator Gauge (Indicators)
Version 1.3
Category Indicators
Indicator Gauge component
Simulation only round gauge/dial for SCADA applications. The range of values displayed is easily adjusted.
SCADA
Fc9-comp-macro.png GetValue
Get the current scale value - this will be the most recent value set using "SetValue", or from the most recent mouse click if the component is in "Control" mode.
Fc9-comp-macro.png SetValue
Set the pointer to the given value on the scale. Returns the angle required to point at the given value.
The value on the scale to move the pointer to.
Fc9-comp-macro.png SetRange
Set the minimum and maximum values of the scale
Fc9-f32-icon.png - FLOAT Minimum
Minimum value for the scale
Fc9-f32-icon.png - FLOAT Maximum
Maximum value for the scale
Fc9-conn-icon.png Range
Fc9-type-15-icon.png Minimum
Minimum value that the meter will show (fully counter-clockwise)
Fc9-type-15-icon.png Maximum
Maximum value that the meter will show (fully clockwsie)
Fc9-type-16-icon.png Startup State
Sets the initial value when loading the project or when the runtime starts.
Fc9-type-15-icon.png Default Value
The default value used on initialise or runtime start.
Fc9-conn-icon.png Title
Fc9-type-7-icon.png Show Title
Decides if the component title is shown
Fc9-type-1-icon.png Title Colour
Title Label Color
Fc9-type-10-icon.png Title Text
Title Label Text
Fc9-type-15-icon.png Title Scale
Controls the size of the title text on the panel, default 1.2
Fc9-type-15-icon.png Title Offset
Distance above component center to draw the title
Fc9-conn-icon.png Label
Fc9-type-7-icon.png Show Label
Decides if a label is shown detailing current setting of the control knob.
Fc9-type-1-icon.png Label Colour
Sets the label colour
Fc9-type-10-icon.png Label Units
Adds a unit to the end of the label
Fc9-type-21-icon.png Label Decimal Points
Number of decinal points to draw on the label
Fc9-type-15-icon.png Label Scale
Sets the size of the label on the panel, default 1.0
Fc9-type-15-icon.png Label Offset
Distance above component center to draw the label
Fc9-conn-icon.png Numeric Labels
Fc9-type-14-icon.png Decimals
Number of decimal places to show on the number labels.
Fc9-type-14-icon.png Text Size %
Height of the number label text.
Fc9-type-3-icon.png Font
Font for the number labels.
Fc9-type-14-icon.png Divisions
Set the number of major scale divisions - these will be given number value labels.
Fc9-type-14-icon.png Subdivisions
Number of smaller scale divisions in between the numbered ones.
Fc9-conn-icon.png Scheme
Fc9-type-2-icon.png BG Color
Colour for the meter background.
Fc9-type-1-icon.png Positive Color
Colour for the number labels for greater than zero.
Fc9-type-1-icon.png Negative Color
Colour for the number labels for value greater than zero.
Fc9-type-1-icon.png Needle Color
