Component: Input ADC (DSP)
Version 1.2
Category DSP
Input ADC component
Allows the values from a buffer to be assigned driectly from an analog enabled pin. Either a single sample at a time or a number of samples. Auto scales the digital value to fill the entire range of the specified buffer type.
DSP
Fc9-comp-macro.png AddSample
Adds a single ADC sample to the current location in the specified buffer. If Auto Scale is enabled then the sample will be scaled to correctly fit inside the buffer. Auto increments current location.
Fc9-comp-macro.png AddSampleArray
Fc9-u16-icon.png - UINT SampleDelay
Number of us in between each sample.
Fc9-type-16-icon.png Buffer Type
Sets the buffer data type, data is automatically scaled to fit and make full use of the data type.
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
Fc9-type-7-icon.png Auto Adjust Scale
Yes: Automatically convert ADC samples to match the full bit depth of the DSP buffer. No: Leave the ADC samples at the native bit depth.
