Component: IntOsc Helper (Matrix Tools)
Author MatrixTSL
Category Matrix Tools
IntOsc Helper component
A component to help configure the speed of the internal oscillator. Currently only supports 8-bit PIC devices.
FREE
The INT OSC helper component is designed to help you configure the rate of the internal oscillator on-board your microcontroller.
It can be found under the Runtime -> Matrix Tools component category.
The oscillator speed drop down menu shows you what speeds are available on your device. Use this to select a speed.
Once you have chosen your required internal oscillator speed copy the code from the Code property.
Paste the configuration code into a C icon at the top of your main macro.
Next change the clock speed in the project options to match your oscillator speed. This will ensure that delays and baud rates are calculated correctly.
Finally you need to enable the internal oscillator in the configuration settings.
If everything is correct then the Info field should confirm that the project options clock speed matches the current speed selection.
Fc9-comp-macro.png Initialise
Called to set the internal oscillator speed to the specified value.
Fc9-type-16-icon.png Oscillator Speed
Shows what internal oscillator speeds are available on the device and allows the user to select an option.
Fc9-type-11-icon.png Info
General info to the user, checks to see if the selected oscillator speed matches the project oscillator speed.
Fc9-type-11-icon.png Code
Code to configure the internal oscillator module. This code must be added to a C icon which should be placed at the top of main.
