Component: K8055D (Third Party)
Version 2.3
Category Third Party
K8055D component
Support for the Velleman K8055 USB input/output board. Allows Flowcode to communicate with up to four K8055 boards, or to simulate them with interactive on-screen controls. All digital and analog I/O functions are supported.
COMMSC
An example project showing the capabilities of the Velleman K8055D board combined with a Pico Technology series 2 scope.
FC6 Icon.png Velleman and Picoscope Demo
Fc9-comp-macro.png GetCount
Read the value of the chosen counter for the currently selected board.
Fc9-s16-icon.png - INT Counter
The counter to read (1 or 2)
Fc9-comp-macro.png GetAnalogIn
Read analog input 1 or 2
Fc9-s16-icon.png - INT Input
Which input to read (1 ro 2)
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png SetAnalogOut
Sets the chosen analog output to the given value (0-255)
Fc9-u8-icon.png - BYTE Output
Which output to set the value for (1 ro 2)
Fc9-u8-icon.png - BYTE Value
Value to set (0-255)
Fc9-comp-macro.png SetDigitalOut
Sets the state of the output given by the output index (1 to 8)
Number of the output to set the value for
Fc9-bool-icon.png - BOOL Value
Fc9-comp-macro.png GetDigitalByte
Read all five inputs at once, returning them as a bit pattern in a byte. The upper three bits will always be zero.
Fc9-comp-macro.png ResetCount
Resets the chosen counter of the currently selected board.
Which counter to reset (1 or 2)
Fc9-comp-macro.png GetDevices
Returns a value representing the available devices. Device is a binary value where bit(N) set = device at address (N) is connected.
Fc9-comp-macro.png Select
Selects the board address to send to and receive data from. Echos the address if the selection is valid. Returns -1 if there is no device available at that address.
Fc9-s16-icon.png - INT Address
The address off the board to be selected (0...3).
Fc9-comp-macro.png SetDigitalByte
Sets all eight digital outputs according to the individual bits of the Value parameter.
Value to send to the selected board.
Fc9-comp-macro.png GetDigitalIn
Read the individual input at the given index (1..5)
Which input to read (1 to 5)
Fc9-comp-macro.png SetCountDebounce
Set the amount of time allowed for switches to settle before being counted as a new event to count.
Which counter to make a setting for (1 or 2)
Fc9-s16-icon.png - INT DebounceTime
Settling time for switch debouncing in milliseconds
Fc9-conn-icon.png Simulation
Fc9-type-7-icon.png Addr 0
Use software simulation to emulate a board connected at address 0.
Fc9-type-7-icon.png Addr 1
Use software simulation to emulate a board connected at address 1.
Fc9-type-7-icon.png Addr 2
Use software simulation to emulate a board connected at address 2.
Fc9-type-7-icon.png Addr 3
Use software simulation to emulate a board connected at address 3.
Fc9-conn-icon.png Hardware
Fc9-type-16-icon.png Scan
Request a scan of the currently connected hardware to detect what Velleman boards are connected and at what addresses. Where hardware is not detected at an addess, a System Panel simulation will be used instead where one has been requested in the properties.
