Component: Keypad (EB014) (E-blocks 1)
Version 1.0 (Release)
Category E-blocks 1
Image Keypad (EB014) component
Preset keypad based around the 3 * 4 unit, as used by the Matrix EB014 E-block
Basic Example
Keypad Example File demonstrating controlling a door lock.
LED is used to show the pin status controlling the door lock.
FC6 Icon.png Keypad Door Entry
WaitPressed
Blocking call that waits for one of the keys on the keypad to be pressed. The index of the key that was pressed is passed back to the user.
This macro has no parameters
BYTE : Index of the first key pressed.
GetAscii
Gets the ASCII value for the current keypress. If no key is pressed then the macro returns the value 255.
BYTE : ASCII code of the pressed switch (or 255 if none pressed)
GetString
Gets the ASCII value for the current keypress and returns in the form of a string. If no key pressed then the macro returns the value 255.
STRING : Single character representing the pressed key, or an empty string if none pressed.
GetNumber
Gets the numeric value for the current keypress. If no key pressed then the macro returns the value 255.
BYTE : Number return value of the pressed key, or 255 if none pressed.
GetIndex
Gets the index value for the current keypress. If no key pressed then the macro returns the value 255.
BYTE : Index of the pressed switch, or 255 if none pressed.
WaitReleased
Blocking call that waits for the keys on the keypad to be released. If no key is pressed then the function will return immediatley.
Simulation macro reference
Port
This property is of type Fixed list of ints and can be referenced with the variable name port.
From here, set the port to which your EB014 is connected.
If you are wiring your own hardware, you can use the 'Custom Pins' setting to allow the
selection of individual pins for each row or column.
