Component: LCD (Adafruit, 20x4) (Alphanumeric)
Version 1.10
Category Alphanumeric
LCD (Adafruit, 20x4) component
Adafruit OLED LCD display capable of displaying 4 lines of 20 characters.
DISPLAYS
Fc9-comp-macro.png Clear
Fc9-comp-macro.png PrintString
Fc9-comp-macro.png PrintAscii
Fc9-u8-icon.png - BYTE character
Holds an ascii value.
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
Fc9-s16-icon.png - INT Number
Fc9-comp-macro.png RAMWrite
Fc9-u8-icon.png - BYTE Index
Values 0 to 7
Fc9-u8-icon.png - BYTE d0
Fc9-u8-icon.png - BYTE d1
Fc9-u8-icon.png - BYTE d2
Fc9-u8-icon.png - BYTE d3
Fc9-u8-icon.png - BYTE d4
Fc9-u8-icon.png - BYTE d5
Fc9-u8-icon.png - BYTE d6
Fc9-u8-icon.png - BYTE d7
Fc9-comp-macro.png ClearLine
Clears a single line on the display before moving the cursor back to the start of the line to allow new data to be displayed.
Fc9-u8-icon.png - BYTE Line
Fc9-comp-macro.png Cursor
Fc9-u8-icon.png - BYTE x
Fc9-u8-icon.png - BYTE y
Fc9-comp-macro.png Command
Fc9-u8-icon.png - BYTE instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
Fc9-comp-macro.png ScrollDisplay
Fc9-u8-icon.png - BYTE Position
Holds the number of positions to shift the display
Fc9-u8-icon.png - BYTE direction
0 = left, 1 = right
Fc9-comp-macro.png Start
Startup routine required by the hardware device. Automatically clears the display when complete.
Fc9-type-5-icon.png Data 0 (11)
Data pin 0 connects to data pin 4 on the hardware
Fc9-type-5-icon.png Data 1 (12)
Data pin 1 connects to data pin 5 on the hardware
Fc9-type-5-icon.png Data 2 (13)
Data pin 2 connects to data pin 6 on the hardware
Fc9-type-5-icon.png Data 3 (14)
Data pin 3 connects to data pin 7 on the hardware
Fc9-type-5-icon.png Register Select (4)
Register select pin, determines if the incoming value is a command or a data byte
Fc9-type-5-icon.png Read / Write (5)
Read / Write pin determines the data direction
Fc9-type-5-icon.png Enable (6)
Enable pin, used to clock data in and out of the device.
