Author
Matrix Ltd
Version
2.5
Category
Alphanumeric
LCD (Generic) component
Generic configurable alphanumeric LCD display component based on the standard Hitachi HD44780 controller IC wiith selectable 4/8 bit interface
FREE
For the LCDs to work with the Flowcode LCD component they need to be connected up in 4-bit data mode.
The 4 data signals actually go to the upper data nibble on the LCD as shown below.
Displaying a numeric value
The LCD will retain the contents of the display, for high speed data we only want to have to write to the portion of the display that can change.
LCD Demo
Clear
PrintString
- STRING
Text
Enter the text or variable to print to the LCD
PrintAscii
- BYTE
character
Holds an ascii value.
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT
Number
RAMWrite
- BYTE
Index
Values 0 to 7
- BYTE
d0
- BYTE
d1
- BYTE
d2
- BYTE
d3
- BYTE
d4
- BYTE
d5
- BYTE
d6
- BYTE
d7
ClearLine
- BYTE
Line
The line to clear, zero being the first (top) line of the display
Cursor
- BYTE
x
Set the cursor position in the X plane, 0 is the left most cell
- BYTE
y
Set the cursor position in the Y plane, 0 is the top most cell
Command
- BYTE
instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
PrintFormattedNumber
- ULONG
Number
- BOOL
Format
0=Signed, 1=Unsigned
ScrollDisplay
- BYTE
Position
Holds the number of positions to shift the display
- BYTE
Direction
0 = left, 1 = right
RawSend
Sends data to the LCD display
- BYTE
data
The data byte to send to the LCD
- BOOL
type
A boolean to indicate command type: true to write data, false to write a command
PrintFloat
- FLOAT
Number
- BYTE
DecimalPlaces
RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
- BYTE
RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
- BYTE
SearchCharacter
Character to look for a replace
- BYTE
ReplacementCharacter
New character value to use in place of the search character.
Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Interface mode
Choose between 4-bit mode, 8-bit mode and 8-bit mode using a port instead of individual pins to improve code efficiency.
Data 0 (11 / 7)
Data pin 0 - Connects to Data 4 on the hardware in 4-bit mode or Data 0 in 8-bit mode
Data 1 (12 / 8)
Data pin 1 - Connects to Data 5 on the hardware in 4-bit mode or Data 1 in 8-bit mode
Data 2 (13 / 9)
Data pin 2 - Connects to Data 6 on the hardware in 4-bit mode or Data 2 in 8-bit mode
Data 3 (14 / 10)
Data pin 3 - Connects to Data 7 on the hardware in 4-bit mode or Data 3 in 8-bit mode
Register Select (4)
Register Select Pin - Informs the display if a command or data is about to be sent.
Enable (6)
Enable pin - Used to synchronise data writes to the display
Use Read/Write Pin
Set to "true" if the displays R/W pin is not hard wired. Set to "false" if the R/W pin is wired to ground.
Display Settings
Rows
Number of lines of characters the LCD can display.
Columns
Number of characters the LCD can display on a single line.
Remap Characters
Used to allow characters to be replaced with alternate characters. Custom characters or characters from the LCD memory map can be used as replacements. Each replacement consumes two bytes of RAM memory and is applied automatically when printing strings.
Delay Timings
Delay in microseconds used in the display send function. Most displays will work with the default value of 100us. Some displays may need a slightly longer delay, 166us is known to work well.
Background Color
Simulation only background colour, the actual hardware will have a fixed colour
Line Color
Simulation only line colour, the actual hardware will have a fixed colour
Text Color
Simulation only text colour, the actual hardware will have a fixed colour
Font
Font to use for simulation, the actual hardware will have a inbuilt fixed font.
