Component: LED (EB004) (E-blocks 1)
Version 1.1 (Release)
Category E-blocks 1
Image LED (EB004) component
An LED matrix made up of standard PCB mount 5mm LEDs.
LED Resistor Calculator Tool
BarGraph
Turns on the first N elements of the array - for generating bar graph metes etc.
BYTE Length
How many items to light up.
LEDOn
Turn on the selected LED.
BYTE Index
Index of the LED to turn on.
AllOn
Turns on all elements
This macro has no parameters
LEDOff
Turn off the selected led.
BYTE Index
PointGraph
Turns on the Indexed LED and turns all others off.
Does nothing if the index is out of range.
BYTE Index
The LED to show.
WriteValue
Write a number which is presented on the LEDs in binary.
BYTE Value
Provide a value to be written to the LEDs in binary
AllOff
Turns off all elements
Simulation macro reference
Output Mode
This property is of type Fixed list of ints and can be referenced with the variable name port.
Choose a single port for all LEDs, or to allocate them to arbitrary pins.
Port
This property is of type Digital port byte and can be referenced with the variable name PortByte.
