Component: LED Cube (Misc Circuit)
Author Ben Rowland 2014
Category Misc Circuit
LED Cube component
LED Cube component for driving 3D arrays of LEDs. A typical cube could consist of 4x4x4 or 8x8x8 but does not necessarily need to be a cuboid.
BASICIO
Fc9-comp-macro.png Clear
Clears the contents of the display to 0x0000
Fc9-u8-icon.png - BYTE SwitchBuffers
0=DoNotSwitch 1=SwitchAutomaticallyWhenDone
Fc9-comp-macro.png RotateShellXZ
Shifts the contents of the display by the number of vertices specified
Fc9-u8-icon.png - BYTE Direction
Fc9-u8-icon.png - BYTE Shell
Fc9-comp-macro.png RotateShellXY
Fc9-comp-macro.png DrawLine
Draws a basic 3D line onto the LEDs
Fc9-u8-icon.png - BYTE X1
Fc9-u8-icon.png - BYTE Y1
Fc9-u8-icon.png - BYTE Z1
Fc9-u8-icon.png - BYTE X2
Fc9-u8-icon.png - BYTE Y2
Fc9-u8-icon.png - BYTE Z2
Fc9-u16-icon.png - UINT Colour
Fc9-comp-macro.png RotateShellYZ
Fc9-comp-macro.png RotateDisplay
Fc9-s16-icon.png - INT X
Number of pixels to shift the display -7 to 7
Fc9-s16-icon.png - INT Y
Fc9-s16-icon.png - INT Z
Fc9-comp-macro.png PWMTimer
Interrupt driven macro to clock out the signals to the LEDs in the cube. To be called as part of a high frequency hardware timer interrupt or software loop to drive the cube hardware, Min Frequency = 60(Hz) * 8(Height) * 32(5-bitColourChannelValue)
Fc9-comp-macro.png ConvRGBToColour
Converts RGB values into a single UINT colour parameter to use with other functions.
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
Fc9-comp-macro.png ConvColourToRGB
Reads the individual RGB colour values from a single UINT colour value. Return Index: 0=Red, 1=Green, 2=Blue
Fc9-comp-macro.png SetColour
Sets a pixel colour in the none active buffer using a 16-bit colour value Bits 0-4 = Red Bits 5-10 = Green Bits 11-15 = Blue
16-bit Colour Value (MSB B5, G6, R5 LSB)
Fc9-comp-macro.png GetColour
Reads the colour value from a single pixel in the active buffer as a 16-bit value. Bits 0-4 = Red Bits 5-10 = Green Bits 11-15 = Blue
Fc9-comp-macro.png DrawCuboid
Draws a basic 3D cuboid onto the LEDs
Fc9-u8-icon.png - BYTE DrawStyle
Sets the draw style - 0=Soild, 1=Edge, 2=Corners
Fc9-comp-macro.png DisplayCharacter
This macro allows a character to be displayed on the screen
Fc9-u8-icon.png - BYTE Font
Size of the font - 0 = Normal, 1 = Double Width, 2 = Double Width and Height, 3 = Double Height
Fc9-u8-icon.png - BYTE Axis
0=XY, 1=XZ, 2=YZ
0=Normal, 1=HFlip. 2=VFlip, 3=HFlip & VFlip
Specifies the foreground colour
Fc9-comp-macro.png ResetRotations
Resets the rotation count variables allowing for a new rotation to be started
Fc9-comp-macro.png SwitchBuffers
Switches the current display buffer to the updated buffer to allow for seamless updates when undergoing heavy calcaulations.
Fc9-u8-icon.png - BYTE WaitForSwitch
0=DoNotWait, 1=Waits for switch to occur
Fc9-comp-macro.png ShiftDisplay
Fc9-u8-icon.png - BYTE DataMode
0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
Fc9-comp-macro.png Initialise
Sets up the data memory and draws the simulated LED cube on the panel.
Fc9-conn-icon.png LEDs
Fc9-type-21-icon.png Width (X)
The number of LEDs wide
Fc9-type-21-icon.png Depth (Y)
The number of LEDs deep
Fc9-type-21-icon.png Height (Z)
The number of LEDs tall
Fc9-type-21-icon.png LED Count
Number of LEDs required by the component
Fc9-type-16-icon.png LED Type
Fc9-type-16-icon.png Common Type
Fc9-type-16-icon.png Wiring Order
Specifies the order of the wiring of the LEDs from lowest bit to highest
Fc9-type-21-icon.png Driver Pre Delay
Number of micro seconds to wait between switching off the driver and clocking out the new signals. Used to remove any ghosting effects visible on the display due to slow driver switch off times.
Fc9-type-21-icon.png Driver Post Delay
Fc9-type-5-icon.png Clock Pin
File:Fc9-type-19-icon.png Data Port
File:Fc9-type-19-icon.png Enable Port
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png LED Size
Size of each LED on the panel
Fc9-type-15-icon.png Spacing
Number of units of spacing between each LED
Fc9-type-7-icon.png Transparent
If set to yes then a LED which is completely switched off will be set to transparent, If set to no then the LED will be shown as black.
Fc9-type-16-icon.png Toggle Pins
Determines if the pins are toggled as part of the PWMTimer macro during simulation. During simulation you probably don't want the pins toggling as it will slow down simulation. The only exception may be if you want to see the signals in the scope window. Does not effect the compiled embedded code.
