Component: LED Matrix (Parallel) (LEDs)
Category LEDs
LED Matrix (Parallel) component
LED Matrix component designed to work using multiple data pins and a single clock pin. Each LED on the display can be controlled in a chain by setting the data appropriatley and then generating the appropriate amount of clock pulses.
BASICIO
Parallel LED matrix example schematic showing 16 LEDs connected using two octal buffer ICs. Data connections to the microcontroller are Data0-Data7, LED_EN, Reset and Clock.
Each clock pulse transfers the output state to the next LED so Data0 goes to LED R0D0 and LED R0D0 goes to LED R1D0 etc.
Example Program FC6 Icon.png ledmatrixp Note. to allow the simulation to run smoothly ensure that the simulation speed is set to normal and you may also want to enable hardware acceleration using the Global Options.
Example Panel Display
Fc9-comp-macro.png StrobeHigh
Sets the strobe pin high. Strobing controls the LED brightness and does not apply to simulation.
Fc9-comp-macro.png StrobeLow
Sets the strobe pin low. Strobing controls the LED brightness and does not apply to simulation.
Fc9-comp-macro.png DisplayString
Prints an ASCII string onto the LED Matrix a column at a time.
Data string to display on the LEDs
Fc9-u16-icon.png - UINT Animation_Delay
Delay in milliseconds between writing to the next column
Fc9-u8-icon.png - BYTE Leadout
Allows the text to scroll completely off the display before returning 0=No, 1=Yes
Fc9-u8-icon.png - BYTE Add_Spaces
Add spaces between each ASCII character 0=No, 1=Yes
Fc9-comp-macro.png ClearLEDs
Sets all of the LEDs in the matrix to the off state.
Fc9-comp-macro.png WriteColumn
Allows a single column of data to be inserted, Acts to shift the rest of the columns across by one.
Fc9-u8-icon.png - BYTE Data
Data to display on the column of LEDs
Fc9-type-16-icon.png LED Type
Active high outputs a logic 1 to set the LED and logic 0 to clear the LED. Active low outputs a logic 0 to set the LED and logic 1 to clear the LED
Fc9-type-14-icon.png Row Count
Number of LED rows
Fc9-type-14-icon.png Column Count
Number of LED columns
Fc9-type-14-icon.png LED Count
Total number of LEDs in the component
Fc9-type-7-icon.png Flip Display
Allows the column and text data sent to the display to be flipped
Fc9-type-5-icon.png D0
Data0 pin which is used to pass the input LED0 value
Fc9-type-5-icon.png D1
Data1 pin which is used to pass the input LED1 value
Fc9-type-5-icon.png D2
Data2 pin which is used to pass the input LED2 value
Fc9-type-5-icon.png D3
Data3 pin which is used to pass the input LED3 value
Fc9-type-5-icon.png D4
Data4 pin which is used to pass the input LED4 value
Fc9-type-5-icon.png D5
Data5 pin which is used to pass the input LED5 value
Fc9-type-5-icon.png D6
Data6 pin which is used to pass the input LED6 value
Fc9-type-5-icon.png D7
Data7 pin which is used to pass the input LED7 value
Fc9-type-5-icon.png Clock
Clock pin used to clock the external buffer IC's
Fc9-type-5-icon.png Strobe
Strobe pin used to control the master display state, strobed at high speed using PWM to set the brightness.
Fc9-conn-icon.png Colours
Fc9-type-1-icon.png On Color
Simulated colour of the LEDs when switched On
Fc9-type-1-icon.png Off Color
Simulated colour of the LEDs when switched Off
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Row Spacing
Simulation row spacing
Fc9-type-15-icon.png Column Spacing
Simulation column spacing
Fc9-type-15-icon.png Width
Simulation LED width
Fc9-type-15-icon.png Height
Simulated LED height
Fc9-type-15-icon.png Depth
Simulated LED Depth (3D environments only)
Fc9-type-16-icon.png LED Shape
Simulated LED basic shape
Fc9-type-7-icon.png Redraw LEDs
Simulated LED redraw option, display will not be updated until the redraw is set to Yes. Automatically revers back to No after the refresh has been performed.
