Component: LED MultiColour Bi (5mm, PCB) (LED)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.1 |
Category | LED |
LED MultiColour Bi (5mm, PCB) component
An industry standard 5mm diameter bi-colour LED. Any color may be chosen, and the leads trimmed to length.
BASICIO
A Bi Colour LED should be connected between two microcontroller I/O pins as shown below.
LEDOff |
Switches off the LED | |
Return |
LEDSetState |
Controls the state of the LED. 0=Off 1=LED Colour 1 2=LED Colour 2 | |
State |
0=Off, 1=Pin1 High & Pin2 Low, 2=Pin1 Low & Pin2 High | |
Return |
LEDOneOn |
Switches on LED one | |
Return |
LEDTwoOn |
Switches on LED two | |
Return |
